Internet interruptions / Router Reboots. ? Problem
- Internet interruptions / Router Reboots. ? Problem
Re: Internet interruptions / Router Reboots. ? Problem
22-01-2012 7:56 PM
22-01-2012 8:04 PM
22-01-2012 8:18 PM
23-01-2012 10:56 AM
Did you manage to set up the other v7? How are you getting on?
Jojo
23-01-2012 5:21 PM
23-01-2012 5:25 PM
27-01-2012 11:01 AM
PT
27-01-2012 4:02 PM
Glad that your router is more stable. I have been playing with mine and I am tending to support those users (on other sites) who blame the restarts on overheating. My router was running quite warm, so I engineered some distance (10mm) between it and the wall and then tweaked the set up of my attached storage to reduce the traffic through the router. It is now significantly cooler, but the temperature does vary with the number of devices attached and the amount of traffic. I notice that the v8 has improved ventilation, so Thomson may have decided that the design is a bit marginal.
I'm really looking for a justification to go and buy a netgear 3700 series, which is faster and has better management of the attached drives and the ftp access. It looks at the moment as if I shall fail.
Frank
27-01-2012 4:20 PM
jim:quote
29-01-2012 4:43 PM
There are a few other threads identifying rebooting routers with ipods but no-one seems to have an answer. Is there anything you can suggest or is it a case of buying a different router?
TIA
PT
29-01-2012 5:07 PM
PS
At Christmas, I had three iPad2, 2 iPhones and one iPod touch, in addition to all the other stuff running for a few days without a problem, so I don't think it's iOS dependent. Could be wrong, of course.
29-01-2012 9:19 PM
David
29-01-2012 10:08 PM
31-01-2012 11:00 AM
How's it going? No, the v7 is not n capable. And even if you were using an n router it would default to b/g if a b/g device is connected to it.
Jojo
31-01-2012 11:08 AM
its been up since I thought his touch took it down. I have deleted the touch off the router devices, reset the wireless on the touch and added let it connect to the router again. Not sure if its made a difference but will get him to play with his touch again after I am happy the connection is stable. I have confiscated it in the meantime so I can test properly and ensure other devices aren't the cause of the problem
PT
