wifi 6e
PaulEngland
wifi 6e
HI
I have a hub 2 and looking to buy a new laptop that has wifi 6e.
I realise that the hub 2 isn't 6e enabled but will the laptop still work ie backward compatible with my hub ?
Paul
5 REPLIES 5
Fixes: 389
Re: wifi 6e
@PaulEngland No reason why it shouldn't.
PaulEngland
Re: wifi 6e
thanks
Fixes: 118
Re: wifi 6e
@PaulEngland
Look at the Laptop WiFi specifications and it should tell you what it supports.
Re: wifi 6e
It would be an odd marketing strategy for a wireless device that would NOT support all generations of wireless networks
Dan.
Fixes: 1,495
Re: wifi 6e
Moderators Note
This topic has been moved from  Broadband to Tech Help
