where does it go :is it worth it?
- where does it go :is it worth it?
- « Previous
- 1
- 2
- Next »
Re: where does it go :is it worth it?
30-08-2010 1:41 PM
You just plug the telephone wire into the laptop and then into the telephone socket at the other end (exactly as we used to do in dialup days).
Of course, the lappy does have to be equipped with a modem. Not sure if they all are these days.
30-08-2010 5:50 PM
Quote from: poppy You just plug the telephone wire into the laptop and then into the telephone socket at the other end (exactly as we used to do in dialup days).
My Dell Inspiron 1545 does not have a telephone modem.... so if I need to go on Dial-Up... I have to use one of these......
http://www.maplin.co.uk/module.aspx?moduleno=221377
Always keep it in my laptop bag, in case we go on hols where there is only a phone line......
30-08-2010 5:56 PM
a very neat modem indeed
30-08-2010 7:42 PM
30-08-2010 7:59 PM
a tiny usb modem and a 1p per minute off peak 56kbit dial service
for when any asdl line goes wrong
didnt know about those wee items shutter , great posts
30-08-2010 11:32 PM
Using another internet service provider isn't necessary; Plusnet offer their own dialup number for anyone who wants to connect at local rates using their normal username and password – you can find it here.
Anyway, I fear this thread is going a bit off-topic… perhaps we should think about dragging things back on to the subject of multifunction printers.
31-08-2010 11:29 AM
Quote from: Be3G Using another internet service provider isn't necessary;
Especially one which falls foul of my grammar pedantry within their opening paragraph.
*tuts*
31-08-2010 8:30 PM
I did not say it was "necessary" ..... I just said that is the one I use....
- « Previous
- 1
- 2
- Next »
