where does it go :is it worth it?
- Re: where does it go :is it worth it?
28-08-2010 8:46 AM
Does the scanned item go to my documents? is a scanner worth the money? etc etc
tx in advance
28-08-2010 8:51 AM
28-08-2010 9:02 AM
28-08-2010 9:18 AM
They are much cheaper than a separate printer and scanner for one rather obvious reason (other than the fact that they share the same box and some of the internals) and that is the scanning resolution is lower than a decent photo quality scanner and the printer usually uses a combined ink cartridge and doesn't produce photo quality prints. The print speed is usually lower as well.
Don't forget - check the cost of ink cartridges as most of them have blocked the use of third party (cheaper) options.
However if you only want to print the odd document and scan for record purposes they will meet your requirements and take up less space
28-08-2010 9:26 AM
28-08-2010 9:38 AM
I wouldn't move to Sheffield (as my previous employer found out when they tried to move me from Poole to Sheffield)
28-08-2010 10:35 AM
Quote from: Oldjim I am too old
Surely not in this day and age when retirement and pensions are being phased out?
28-08-2010 10:56 AM
Quote from: Oldjim I wouldn't move to Sheffield
You'd have the Pennine Way on your doorstep...a nice Sunday afternoon stroll
28-08-2010 11:37 AM
This is sometimes quicker and easier than scanning into Documents and then printing off.
It's not the cost of the machine that is the issue - it's the price of the inks when you have used the provided ones (which are always only half full anyway).
If you are going to get one then buy one with separate colour cartridges as they are not so wasteful. Epson inks tend to be best priced. HP are quite pricey.
I have an Epson DX3850 which is still working perfectly about 3 or 4 years and in the life of these machines it's not bad as they don't always last very long before heads or something or other packs in.
29-08-2010 12:50 PM
29-08-2010 6:41 PM
S
Decisions, decisions.... PRINTER/Copier/FAX
You also need to think about the "location" of this wonderfully useful objet d`art !....
29-08-2010 7:00 PM
30-08-2010 11:41 AM
I do find the copy facility of my Canon MP190 very useful.
30-08-2010 12:01 PM
I rarely use this too but it is occasionally handy as there are companies who will not accept emails but will accept faxes. This happened to us when we had an insurance claim a good while ago so it's nice to know that it is within the functionality of the computer if necessary.
30-08-2010 1:12 PM
