unlocking openreach eci modem
roberkwild
hi all,
does anyone know of any good walkthroughs in how to unlock one of these?
cheers,
rob
4 REPLIES 4
chenks76
All Star
Fixes: 12
Re: unlocking openreach eci modem
i think it's only the Huawei that can't be tinkered with IIRC.
core2lee
Dunno if this is relevant?
https://wiki.openwrt.org/toh/bt/vg3503j
Riza
Well the ECI is supported, but to the flash OpenWrt (which also has the linestats info just like the Huawei) you'll need some soldering skills Funny
http://forum.kitz.co.uk/index.php/topic,15918.0.html
ashwinmevin
BT ships a variety of modems for its VDSL/Infinity product. There are ongoing discussions regarding the merits of each, but what all do have in common is that they are locked-down and inaccessible. The Huawei HG612 is theoretically the easiest to root, as described.The ECI B-FOCuS V-2FUb/I Rev. 1B can be unlocked via a serial connection without any need to replace the stock firmware.
internal clips by removing the screws beneath the two rubber feet and then prising the case apart, starting with the rear corners and then moving to the smallest clip – above the ethernet ports. That made freeing the sides easier, and then the remainder of the lid could be released.
The pin-out mentioned at the above link appear correct: pin 2 is TXD, pin is 3 RXD and (unlabelled) pin 4 is GND. The TXD pin on the PCB must connect to the RXD pin on the UART/USB adapter, and the RXD pin on the PCB must connect to the TXD pin on the adapter.
