two routers on my connection?
gerry49
I am setting up a synology nas on my network and the nas is telling me there are two routers on my network and they need to be bridged. There is only one router in my house. I have found out that there can be a second router somewhere next down my line possibly in an exchange. I have carried out a trace route test and have come back with possibly the second router. My router ip is 192.168.1.XXX and the next ip down the line is 172.16.15.58 and 172.xxx.xxx.xxx is usually another router.
How can i get these routers put into bridging mode?
13 REPLIES 13
Fixes: 144
Re: two routers on my connection?
@gerry49 welcome to the forum.
Can you share the traceroute output please?
plusnet do use some 172 addresses so it might be a false result
EDIT: does the NAS have a cli? if so if possible traceroute from the NAS
gerry49
Thanks for the reply.
Here is the result from my traceroute test.
Tracing route to dns.google [8.8.8.8]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.254
2 3 ms 3 ms 3 ms 172.16.15.58
3 * * * Request timed out.
4 8 ms 7 ms 7 ms 132.hiper04.sheff.dial.plus.net.uk [195.166.143.132]
5 8 ms 8 ms 32 ms peer3-et0-0-4.slough.ukcore.bt.net [194.72.16.58]
6 8 ms 8 ms 8 ms 109.159.253.75
7 9 ms 10 ms 9 ms 74.125.253.31
8 10 ms 9 ms 9 ms 216.239.63.219
9 9 ms 9 ms 8 ms dns.google [8.8.8.8]
Trace complete.
Moderator's note by Mike (Mav): Post released from Spam Filter.
gerry49
I posted the traceroute from my pc but it looks like it has not posted on here. Can anyone see it? I will do another one when i,m at my PC later.
Wondered why i did not have a response.
Fixes: 144
Hi, some posts sometimes get marked as spam, which might explain it's non arrival.
Fixes: 563
@gerry49 and the next ip down the line is 172.16.15.58 and 172.xxx.xxx.xxx is usually another router.
The 172... address is not a router its the BT gateway. Since its the other end of your PPPoE connection there's no need for it to have a publicly routable address and so BT wholesale use the 172... for gateways on their WBC (Wholesale broadband connect) network.
As @Dan_the_Van says, the NAS is making a false assumption that a 172... address is a router
gerry49
Ah, ok thanks. I,ll fire up the pc and do the trace route.
gerry49
Done it on this laptop. Same result.
1 404 ms 7 ms 2 ms 192.168.1.254
2 44 ms 31 ms 47 ms 172.16.15.58
4 154 ms 216 ms 66 ms 132.hiper04.sheff.dial.plus.net.uk [195.166.143.132]
5 13 ms 18 ms 47 ms peer3-et0-0-4.slough.ukcore.bt.net [194.72.16.58]
6 15 ms 25 ms 10 ms 109.159.253.75
7 23 ms 130 ms 201 ms 74.125.253.31
8 13 ms 433 ms 201 ms 216.239.63.219
9 21 ms 230 ms 310 ms dns.google [8.8.8.8]
Trace complete.
Third one always times out. 1. Is the router here, 2. is the one i suspect is the second router elsewhere.
Fixes: 366
That second address is not a router as such - it is the gateway address to the WBC, and therefore nothing to do with you or your internal network.
gerry49
Thanks for the info. So i guess i will have to set up the Nas manually.  That should be fun.
Fixes: 144
@gerry49
The traceroute is very much as I expected it to be, as I said a false result.
gerry49
Just looked at the router setup on the nas again and it says " we will help you setup a connection between your nas and the router. before the setup.
It will take a while to run the checklist below.
Checking network interface
Checking gateway connection
checking network connection
checking DNS Server
Checking network environment
Detect router information
Everything is ok except checking network environment.
This message appears
"Two or more routers were found in your network. Consult your ISP to set the modem/ router to bridge mode. or try setting your router to bridge mode."
Could it be seeing my switch as a network router. Router is connected to a switch and everything goes from that.
Could the "IN" be the clue?
Champnet
Fixes: 19
I’ve a couple of Synology boxes and setup many others but never seen that message.
Probably cause I configure the network setting manually and it looks like you’re using an automatic process ?
Fixes: 144
@gerry49
I very much doubt a switch would be detected as a router, the ones you are using would need a IP address which would really only be used for management purposes not routing, the 172. IP Addresses from your traceroute are outside of your home network.
