problem with macros
- problem with macros
problem with macros
04-07-2008 9:35 PM
When I close this, the next one pops up with---------
The macros in this project are disabled. Please refer to the online help or documentation of the host application to determine how to enable macros.
I don't use macros. I don't think I have done anything different to make these boxes appear, and I don't know how to get rid of them. Please can someone help.
Re: problem with macros
04-07-2008 11:31 PM
You need to find out what the macro is and if its genuine like Adobe then enable it. You should be able to see what macros you have installed by viewing macros (depends on your version of word) the worrying bit is expired or revoked signature but this could be some old software you have installed
05-07-2008 12:43 PM
My computer is from Dell and it was set up when it arrived in 2005.
I have looked in the macros bit of tools but still don't know what to look for. After your advise about Adobe I now remember a message recenly to update, which I did at the time. As I don't use this programe I have removed it but, the problem still persists.
Thaks again for your help
regards
05-07-2008 1:20 PM
I assume you are using word 2003 - check by opening word then clicking on Help then About Microsoft Office Word - if it is Office 2003 does it say sp3 at the end - this is what mine says
05-07-2008 2:30 PM
Thanks for responding, you guys are something else.
I get these messages when I open word. when I checked the help found out it is word 2002 and I do have the sp3 after it. Didn't know about all that until you have just put me right, thanks.
Regards
05-07-2008 3:38 PM
Can you follow the instructions given here http://support.microsoft.com/kb/q301638/ and report back
05-07-2008 9:37 PM
Downloaded the help link you gave me. Only got so far. method 1 I got as far as Modify in nos 3 the box that came up then didn't seem to correspond with the what should be there. i got the modifying location dialog box but there was nothing in it apart from the title "Start Up"
thanks
05-07-2008 11:13 PM
In the meantime some of the regulars may be able to help
05-07-2008 11:49 PM
Before you do it I would be extra vigilant and do a virus scan of the pc first.
The chances are 99.9% its a harmless macro.
06-07-2008 10:06 AM
If you open Windows Explorer or My Computer and go to Program Files/Microsoft Office/Templates there should be a file called normal.dot (If there isn't can you do a search in the C drive for normal.dot)
Can you move this file to desktop - just a convenient temporary store
When you start Word it won't find it and therefore will create a new one with the default settings.
If this fixes the problem then all you need to do is change how you want Word to look and it will change the new file accordingly.
If, however, it doesn't fix it you can move the file back to where it came from (after closing Word) and you will be back where you were before.
10-07-2008 1:52 PM
Well sorry to say I tried what you told me and still no joy. This is getting so frustrating, i'm getting all this great help but nothing seems to work.
Any more sugestions please!!!
Regards
