pnhub1
durkar29
pnhub1
pnhub1
What is it?
How do I remove it from finder?
5 REPLIES 5
Gel
Champion
Fixes: 29
Re: pnhub1
Fixes: 1,495
Re: pnhub1
Finder is the MacOS file manager,
Your router - the hub one - will show in there as it has a shareable device.
Nothing to worry about Smiley
Fixes: 1,495
Re: pnhub1
Moderators Note.
Moved to tech help as it’s not an issue with broadband or on service
durkar29
Re: pnhub1
Thanks for that. But why does it show as "Connection Failed"
Fixes: 1,495
Re: pnhub1
because you don't have a drive attached to the usb port.
