Cloudflare dns
- Cloudflare dns
Cloudflare dns
26-04-2018 2:51 PM
Any thoughts on 1.1.1.1 1.0.0.1 ?
Re: Cloudflare dns
26-04-2018 9:24 PM
Yep, I think the graphs need some context as to what they mean to someone who doesn't know what the heck they mean... ![]()
Re: Cloudflare dns
26-04-2018 10:40 PM
Maybe a little bit of light reading perhaps....
Re: Cloudflare dns
26-04-2018 10:52 PM
Nah, I've got a sofa to keep the cushions pressed down on, too busy... ![]()
I was thinking more what the coloured bars mean in the graphs, as in, good, bad, normal, fault-ridden? Gotta have context to make sense of a bar graph... ![]()
Re: Cloudflare dns
26-04-2018 11:10 PM
In that case here's the couch potato version just for you https://www.youtube.com/watch?v=vmEkB-M28fE
Re: Cloudflare dns
27-04-2018 3:48 AM
Thought about watching, but I decided Cheers was more funny... ![]()
Re: Cloudflare dns
27-04-2018 10:46 AM
1.0.0.1 and 1.1.1.1 are massively faster than Plusnet.
I also use dnsmasq to cache domains in memory - which can give sub-millisecond response times. ![]()
Re: Cloudflare dns
27-04-2018 11:11 AM
Not been happy with cloudfare wrt websites "protected" by them, so wouldn't trust them with DNS, will stick to Google via my pi hole server.
Re: Cloudflare dns
27-04-2018 11:29 AM
I was just about to start looking into the data side, it is said your data is deleted on a regular basis but your ip is logged.
I've only done a bit of testing so far but it seems pretty smart ish, as for add blocking I'm using this script to block adds at the router level which works pretty fast. Plusnet has been a little sluggish for me over the last while which has prompted me to look at this again, even better with fresh view 1.1.. I guess
_rogue=0.0.0.0
echo -e "n=1\nwhile ! wget -q -O /tmp/hsts http://winhelp2002.mvps.org/hosts.txt ; do\n\t[ \$n -gt 5 ] && break\n\tlet n+=1\n\tsleep 60\ndone\ngrep \"^0.0.0.0\" /tmp/hsts | grep \"^0.0.0.0\" | grep -v localhost | awk '{print \"$_rogue\\\t\"\$2}' | tr -d '\\\015' >/tmp/dlhosts\nrm /tmp/hsts\nkillall -HUP dnsmasq" >/tmp/wh
sh /tmp/wh &
I did like the look of Pi-Hole but after using two pi's for dns for a year or so I wanted to move onto something else, very good idea all the same though.
Re: Cloudflare dns
27-04-2018 11:45 AM
CDNPerf https://www.cdnperf.com/ shows google to be the fastest, but I just can't bring meself to use them though sadly.
Re: Cloudflare dns
27-04-2018 12:47 PM
I'm not convinced that google is faster in the UK at least.
Mr potato-head, please stay on your sofa as this may make your head really hurt
Re: Cloudflare dns
27-04-2018 3:54 PM
Perhaps you could make a script to randomly set your DNS servers from a choice of say either Plusnet's, Google's or Cloudflare's, so that you don't know which ones are being used, and see if you can tell the difference.
Re: Cloudflare dns
27-04-2018 4:27 PM - edited 27-04-2018 4:28 PM
I'm quite happy Cloudflare are faster than plusnet, I was just curious as to why @HairyMcbiker thought google was faster.
But for sure DNSPerf https://www.dnsperf.com/#!dns-providers,Europe think they have 1.1.1.1 on top.
which still leaves the security question of the dns provider.
Re: Cloudflare dns
27-04-2018 4:41 PM
Re: Cloudflare dns
27-04-2018 4:45 PM
ahh sorry my bad
