plusnet - GP6H ROUTER.
Tricker444
HELLO.
Please bear with me this is completely new to me and the only reason I have taken this course is, I have been informed that your community could help me out.
The plusnet - GP6H router I am using works perfectly well, but, I would like to reposition it for my own convenience. The problem is the power plug length is to short. Now I know that I can obtain an extension lead, but, after looking online I have found that there is quite a difference in sizes.
Could anyone in your community give me the exact specification of the extension I would need.
Many thanks in advance.
Best...
3 REPLIES 3
Fixes: 401
Re: plusnet - GP6H ROUTER.
@Tricker444  Welcome. to the forum.
Why not use a mains extension lead? Low voltage extensions can cause issues due ro the increased voltage drop.
Tricker444
Thanks for the reply Baldrick1.
But having given the problem further though I've decided the easiest way to solve the problem - I should have though it through more thoroughly before posting the " problem " - is to buy a longer DSL cable.
Anyway, thanks again.
Best...
Mav
Fixes: 512
Moderator's note(s):
Thread moved from Introductions to Tech Help.
Forum Moderator and Customer
