pfSense and plus.net setup
cphillips1
I currently have the following:
Internet -> BT Openreach modem -> Netgear R9000 router -> LAN (comprising ESX server and various VMs)
I would like to switch my Netgear R9000 router to become an Access Point and have a pfSense installation doing the work of that as the router.
How do I setup the WAN side of pfSense?  Do I need to set it to use PPPOE or DHCP/Static?  My account with Plus.net has a static IP.  The more I read on the internet the more confused I become!
At the moment I have pfSense running as a VM (no VLAN's involved) on ESX.
More than happy to provide any further details as needed!
Thanks in advance.
2 REPLIES 2
Fixes: 587
Re: pfSense and plus.net setup
@cphillips1
You set it for PPPoE and obtain IP from ISP.
It matters not whether you have a dynamic or static IP on your account. Effectively, having a static IP just means that you will always be allocated the same IP.
cphillips1
Thanks, I set it to PPPoE, entered my username and password for plus.net and it sprang into life.
I can't get out to the internet at the moment so looks like I have an issue with DNS (I have a Windows Domain on my network and use that for DNS) so need to do some more troubleshooting but have made progress!
Moderators Note: Full quote of preceding post removed as per Forum rules
