mute button
- Re: mute button
- « Previous
- 1
- 2
- Next »
Re: mute button
31-08-2015 12:15 PM
I would have thought it was just a generic Keyboard and wouldn't need a separate driver as the windows driver is ok ??
have you checked you have no exclamation marks in Device manager , its possible its a USB driver is corrupt , if i all ok try reinstall USB drivers
Re: mute button
31-08-2015 2:11 PM
Quote from: nanotm if it has drivers for w7 or w8/8.1 download them and use the driver update >manual functions and install the older drivers for it, the problem with oem kit is often they only provide the drivers in the version of the OS they supply and newer versions delete that sort of thing /
Oh deary me....... not quite true......
My old dell laptop had a perfectly good and usable "touchpad" mainly because I did not use it for eight years... always used el-cheapo generic mouse... (s)... and Windows 10 accepted the generic mouse...but would not.... repeat not... allow the use of the Dell driver to disable the touchpad on plugging the mouse into the usb port..... why...
Because windows 10 blocked the dell driver... ...... why would it do that ?
well, it`s simple really.... WIndows 10 decided that the Dell Driver, in use for XP, VIsta, AND windows 7 pro.... was DANGEROUS to windows 10...
Doing a "rollback" to previous drivers did not solve the problem either....
Re: mute button
31-08-2015 3:00 PM
because its an old bit of kit that had an old driver that wasn't vetted to work with w10, your should of sent the driver as a report to M$ for them to check and verify and add to the list of good things or provide you with an alternative, that the old driver from xp worked with w7 doesn't make it a windows 7 driver though it is still an xp driver....
then again M$ has also said a lot of older kit wouldn't be compatible or work under windows 10 which you could of read on the upgrade assistant before actually installing w10 and saved yourself the trouble (w8/8.1 did the same thing with some hardware it detected in the past on my laptop as well) still some people rather slag off new things rather than spend a bit of time and get to know them and evolve with the times /
Re: mute button
31-08-2015 3:24 PM
Not slagging off the new things..... just pointing out that what you say is not always true...
you may think you know the answer to every problem on the forum, but it just is not the case... and I was pointing out that fact... (not for the first time)....
WIndows 10 will be ok for those kids it advertises it to on the telly... those kids "that will grow up with windows 10"... I am not one of "those kids"... when I am told that a new "upgrade" will make things easier, faster, more reliable, by Microsoft, I expect it to be just that....
not a dumbed down version of something that 18month old kids will grow up with....
an "upgrade" is supposed to just work better... I tried it... and it doesn`t.... .....
Windows 10 does not do that for me, so I have reverted back to Windows 7.... because it works... and really...it doesn`t need to be upgraded...
As a point of interest.... I did, indeed, contact Microsoft.... that is how I now know that the driver is "dangerous".... their word.... not mine..!>.. oh come on... really ?
You said,...
If that were true... then why would that same company say that my Dell Inspiron of 8 years vintage... which was running windows 7, was compatible with windows 10.....
Either you , or microsoft are telling porky pies.... methinks...
You said,...
Re: mute button
31-08-2015 5:35 PM
In the days of Windows 3.1 I never had "problems" with keyboards or mice.
Re: mute button
31-08-2015 5:48 PM
They had those wierd round plugs with little pins then. USB - who needs that
Re: mute button
31-08-2015 6:10 PM
And when you "upgraded" to the next "new" system.... everything still worked..... windows 10...eat your heart out
Re: mute button
31-08-2015 10:17 PM
Not quite Right Shutter , a lot of OS upgrades caused driver problems ,, same as win10 .
So prior to win 10 upgrade not everything upgraded smoothly From win xp to win 7 was a nightmare for some , but at least thid time MS did say on older hardware there will be problems
- « Previous
- 1
- 2
- Next »
