monitor resolution problem
dgk
I have a AOC Q2770PQU monitor which has a resolution (native) of 2560 x 1440.
On my pc Win 10 now has a max resolution of 1920 x 1080. It also has my monitor as a AOC 2770G4.
Help would be appreciated in sorting this out.
I have dual monitors, my other secondary monitor is a LG and it is behaving normally.
I think this problem arose after a crash, in that I came back to my bit PC expecting it to be on, found it off restarted and found this problem.
3 REPLIES 3
Re: monitor resolution problem
@dgk This driver may be of interest to you:
http://aoc-europe.com/en/products/q2770pqu#support-download
dgk
thanks
ReedRichards
Seasoned Pro
Fixes: 25
Best to perform a System Restore under these circumstances.  However some versions of Windows 10 have a bug which prevents System Restore from completing properly unless you first delete or rename the (hidden) folder C:\Program Files\WindowsApps  .
