iPlayer Desktop hitch, so how do I open a wmv Windows Media file?
- iPlayer Desktop hitch, so how do I open a wmv Wind...
12-06-2012 7:43 PM
Although the wmv file downloads OK I cannot open it, an Error Message indicates that I am not authorised.
An accompanying website address does not open.
Please can anyone offer me guidance?
Regards......
Re: iPlayer Desktop hitch, so how do I open a wmv Windows Media file?
12-06-2012 8:31 PM
e.g.
http://www.bbc.co.uk/iplayer/episode/b00mtm6q/Brian_Aldiss_Presents_Brian_Aldiss_Presents_Impostor/ - this works
http://www.bbc.co.uk/iplayer/episode/b00m9p2w/Hothouse_Episode_1/
http://www.bbc.co.uk/iplayer/episode/b00mdx7n/Hothouse_Episode_2/
These fail - they don't even playback...
http://www.bbc.co.uk/iplayer/episode/b00pgqf2/Red_Dwarf_Infinity_Welcomes_Careful_Drivers_Episode_4/ - this works...
12-06-2012 8:45 PM
12-06-2012 8:51 PM
In any case I can download some radio and all video with get_iplayer - which doesn't need flash player.
Example
12-06-2012 9:17 PM
Have you tried to convert the .wmv file? to another format.... e.g MP4 or DIVX or AVI ?
You can do this with.... ATUBE CATCHER free download from here.....http://atube-catcher.dsnetwb.com/video/
12-06-2012 10:10 PM
ATUBE CATCHER looks interesting, 'though I've not managed a conversion yet, seems to report a fault. I'll persevere.
I guess I'll want to play the video in Windows Media. Will the formats you suggest do the trick, shutter?
Trying those conversions don't manage to complete.
I'll have another go when I can spend a bit of time.
Thanks and regards....
13-06-2012 7:52 AM
- the file is protected by DRM but you can't acquire a license
- the file is corrupt
- it's not actually a WMV file
If you can't play the file for one of those reasons, you probably won't be able to convert it either.
13-06-2012 8:13 AM
I think I'll give up!
I presume others are having problems with downloading into iPlayer Desktop and the BBC will sort it, in due course.
Regards.....
13-06-2012 8:20 AM
As ejs said....if it is corrupt or protected, you won`t be able to convert it..
You might like to have a look at GOM player, which is also free,
so you can play many different file formats, and not be stuck with .wmv for windows media player...
13-06-2012 8:28 AM
As an aside, the iPlayer desktop on Linux relies on having the latest version of Adobe AIR- which Adobe have already withdrawn support for
In the past I have tried downloading the wmv files, with the intention of trying to stream them from a networked hard drive to my set-top DLNA player, but I have never managed to work out how to get the DRM working.
13-06-2012 8:33 AM
I guess it'll be best for me to wait 'til the BBC sorts it out.....I just thought they'd do it rather more quickly, it's been such a good service so far.
Regards....
13-06-2012 10:09 AM
Quote from: purleigh It looks like the BBC are aware of a download problem with the iPlayer desktop, as the following link was posted 4 days ago - http://iplayerhelp.external.bbc.co.uk/help/announcements/programme_latest_issues
As an aside, the iPlayer desktop on Linux relies on having the latest version of Adobe AIR- which Adobe have already withdrawn support for- http://helpx.adobe.com/air/kb/install-32-bit-air-linux.html
You don't need AIR to run get_iplayer - well I've never loaded it, ever!
Furthermore, the BBC don't use DRM for their programmes - although they do obfuscate the format in which these programmes are supplied.
13-06-2012 5:17 PM
13-06-2012 7:11 PM
Up to a few minutes ago, I was one of those Users!
However, a contributor to the BBC Forum suggested ".....close iPlayer, go to your repository and delete all folders that are too small to hold programmes....."
My Repository Folder contained various files and fragments that when cleared, iPlayer Desktop worked again!
If there are others with this issue, I hope it helps as it helped me!
Regards and thanks everyone who have responded to my original query.....
