how to delete a invalid CLSID
slanjavah
Can anyone help how do I find and delete the following :
The COM component CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A} references an invalid CLSID. These are often left behind after uninstalling software.
Jim
7 REPLIES 7
Peter_Vaughan
Re: how to delete a invalid CLSID
Try ccleaner which can find and remove orphaned registry entries as well as lots of other things.
samuria
You can just open regedit and search for the clsid once its found it simply delete it. To be safe save the key as a .reg file  first  by selecting export so you can put it back should it be the wrong one.
slanjavah
Hi there ccleaner finds this but does not delete it syas to manually delete from registery, I have searched but cannot find it to delete
Fixes: 1,495
Looks like that is for Adobe flash, are you having problems? There shouldn't be any real need for you to delete the key.
slanjavah
Not having any problems as such just that get message when pc boots
Fixes: 1,495
I think you can download an uninstaller for flash from the Adobe web site which might help.
Fixes: 1,495
Linky: http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_14157
