folder problem ?
- folder problem ?
folder problem ?
14-10-2012 10:38 PM
ok question , windows normally lists alphabetically well it did until tonight the wife was playing some music of HD 2,, 1 TB, i have 42 gig of music she couldn't find some tracks wierd i thought anyhow i had a look & for some reason windows now has arranged them from Z to A not A to Z any ideas how to revert back to normal ?
3 REPLIES 3
Re: folder problem ?
14-10-2012 10:52 PM
click on Name
14-10-2012 11:22 PM
Jim's advice is correct if you are looking at the detailed view where it shows in addition to the file name the date, type and size (plus any other columns you've added). Clicking any of the column headings once sorts that column ascending, a second click reverses it.
If you are not in the detailed view and just have a list of file names or icons select Sort by from the View menu and pick the attribute you want to sort by. Again making the same selection twice reverses the sort.
15-10-2012 6:52 AM
thanks
