constant change of local IP.. stop!?
marc2
seems a bit pointless to have a static IP set if my internal keeps changing and the plex server then cannot direct connect.  will connect but indirect so slower
I have asked Plusnet support but got no where.
every few days i have to enter the router and reset game sharing for my plex server, edit ip and chose my pc hostname.  it then works fine until the local IP changes again.
anyway i can stop this?
ty
67 REPLIES 67
Browni
Aspiring Hero
Fixes: 60
Re: constant change of local IP.. stop!?
Give the PC a static IP address?
marc2
i have a static external but is no use when the internal changes so often and i have to reset the new internal to associate with my pc
i dont want the internal to change or at least auto reset itself to my pc hostname
DaveyH
Champion
Fixes: 12
What @Browni is saying is you need to assign your Plex server an static internal/local IP address.
marc2
yeah thats part of my question
if i set a fixed ip i get no connection
how can i set plex to stay to a certain ip all the time and thus route through?
bobpullen
Fixes: 316
What router are you using?
marc2
technicolour 582
7up
Fixes: 17
Two ways:
1) Assign your device a static IP in its own TCP/IP settings (you *might* be able to do this in your router config but not all offer that feature)
2) Run your own DHCP server and configure it to give that device the same IP each time it renews the lease on that ip address. You'd need to turn off your existing dhcp server in your router for this option.
marc2
thanks, good answer
but this is basic stuff as per port forwarding, the system should know
no point in port forwarding if keeps changing
Browni
Aspiring Hero
Fixes: 60
If you assign a static IP to the PC as I said in the first reply in this thread it won't change. That is basic stuff.
RPMozley
Fixes: 13
If you're using the tg582n then login to it, go to Devices in the Home Network section. From there select your PC running the plex server, click configure top right of screen. Then check the box "Always use the same IP address" in the addressing section. Save and done.
That's RPM to you!!
7up
Fixes: 17
@marc2 wrote:
thanks, good answer
I've already explained to you how to get around the ip addresses being changed. Either go static or use a different dhcp server on your network. I've no idea if your router supports static IP addressing but thats the best place to look.
RPMozley
Fixes: 13
See post 7 @7up the "technicolor 582" and as you may know port forwarding only works with DHCP client on auto not a static device set IP address with this router.
That's RPM to you!!
marc2
this may have resolved
need further testing
marc2
great that plusnet dont offer any technical support what so ever
