backing up to a usb drive on the router using synctoy
- backing up to a usb drive on the router using sync...
23-06-2017 5:20 PM
OK
I did the basics and setup the drive from the router interface and setup a mapped drive on the XP computer then ran synctoy
All the folders were created but no files were transferred I tried setting the security permissions but it still wouldn't work
Obviously I am missing something but I have no idea what
The router is a Billion 8800nl
Just to get things going I am trying the same thing with the hard drive connected directly to the computer and that is working as it should
Re: backing up to a usb drive on the router using synctoy
23-06-2017 7:57 PM
Daft question... are you using different file formats on the two drives such as NTFS v FAT32 ?
Alternatively does the drive have write protection? - EG is it a memory card in a usb dongle for instance? (some 3/4g dongles have microsd slots)
23-06-2017 9:06 PM
is the drive mounted under disk manager or did you just add a network drive ?
what file format is the drive in?
how large are the files your trying to do a sync with? theres posts on the billion forum that suggest anything over 9gb isn't going to work due to buffer handling /
might be that you need to do the sync plugged into the pc to start off with and then it will work to change things incrementally afterwards via the hub
24-06-2017 10:09 AM
files are all small
format is ntfs
actually I don't think it is going to work the way I want as apparently you need to login to the drive every time
I will leave it as it is for a long time as I am going in for a new hip next week and subsequent mobility is going to be a major problem for several months
24-06-2017 1:27 PM
Good luck with the new hip Jim.
24-06-2017 2:08 PM
Three cheers for @Oldjim as he heads off to hospital.
Hip Hip Hooray. Oh! On seconds thoughts maybe not.
Take care of yourself Jim and best of luck with the operation.
28-06-2017 6:44 PM
From hospital
Well that stuffs it for older operating systems
To kill the latest ransomware disable SMBv1protocol permanently
