XP Advice
- XP Advice
XP Advice
01-01-2014 2:42 PM
Would it be wise to update to Windows 7 or is it quite safe to use XP on the internet after that date ?
Re: XP Advice
01-01-2014 2:51 PM
Re: XP Advice
01-01-2014 2:56 PM
Re: XP Advice
01-01-2014 4:36 PM
My better half's computer is XP and does everything she wants so a new computer would be of little practical benefit
I intend to keep it going on XP until Kaspersky no longer supports it - then I will either get a new one of install a later operating system
Re: XP Advice
01-01-2014 4:47 PM
Quote from: ejs If your computer is old enough to be running XP, I'd think it's time for a new computer - and get one with a SSD.
Now that is just throwing money away. It really depends on what you want to use the pc for. For general browsing and the odd email/doc then one with an ssd is complete overkill. This PC I use daily came with xp home originally, I got it sans HDD as the previous user found it too slow, so Freecycled it - this was 4 years ago! I have replaced the hdd's several times, and just replaced the 1.8Ghz duo with a 2.25Ghz duo processor. Still fast enough for me most of the time.
I will not say what OS I would install on it (op's one) either
Re: XP Advice
01-01-2014 4:47 PM
I recently received a used/discarded W7 system (hard disk failure, so user bought a W8 unit to replace it) which I was able to reinvigorate (legally) with just a new hard disk.
And soon I'll be getting another from my son who wants a faster PC with W8 - he's from the iPhone generation and prefers that..
I see W7 as a "keeper" in the same vein as XP was, but my XP systems will soon be reduced to just a secondary boot alongside something else, mostly Vista.
Re: XP Advice
04-01-2014 2:49 PM
Re: XP Advice
09-01-2014 10:18 PM
This site (which I don't trust) http://www.theinquirer.net/inquirer/news/2322065/microsoft-cancels-security-essentials-for-windows-x... claims that
Quote What is Windows XP end of support?
Microsoft has provided support for Windows XP for the past 11 years. But now the time has come for us, along with our hardware and software partners, to invest our resources toward supporting more recent technologies so that we can continue to deliver great new experiences.
As a result, after April 8, 2014, technical assistance for Windows XP will no longer be available, including automatic updates that help protect your PC. Microsoft will also stop providing Microsoft Security Essentials for download on Windows XP on this date.
If you continue to use Windows XP after support ends, your computer will still work but it might become more vulnerable to security risks and viruses. Also, as more software and hardware manufacturers continue to optimize for more recent versions of Windows, you can expect to encounter greater numbers of apps and devices that do not work with Windows XP.
However a bit more digging turned up this http://www.zdnet.com/microsoft-may-end-antivirus-updates-on-xp-in-april-7000022645/
Quote On the End of Life webpages of the Microsoft website, the company explained that it will withdraw support for its free security product Microsoft Security Essentials (MSE) in 90 days.
http://arstechnica.com/information-technology/2014/01/security-essentials-for-windows-xp-will-die-when-the-os-does/
Quote Microsoft will not guarantee updates of our antimalware signature and engine after the XP end of support date of April 8, 2014. Running antivirus on out of support operating systems is not an adequate solution to help protect against threats. Running a well-protected solution starts with using modern software and hardware designed to help protect against today’s threat landscape. In addition, Microsoft recommends best practices to protect your PC such as: 1) running up to date antivirus, 2) regularly applying security updates for all software installed, and 3) using modern software that has advanced security technologies and is supported with regular security updates.
Re: XP Advice
09-01-2014 10:53 PM
If there was a MS upgrade at a sensible cost which would run on her existing hardware I'd pay for it.
We will have to continue to use XP in spite of the risks.
Re: XP Advice
09-01-2014 11:23 PM
Re: XP Advice
10-01-2014 12:09 AM
Quote from: jelv It however would NOT be fast enough if upgraded to Windows 7 as it is nowhere near the minimum spec. - let alone Windows 8.
Have you actually checked?
I've loaded W8 on some SERIOUSLY OLD XP hardware and it ran surprisingly well.
It uses less resources than W7, though does have some specific requirements - run the compatibility tester.
Re: XP Advice
10-01-2014 8:15 AM
Re: XP Advice
10-01-2014 9:35 AM
Recently installed Linux Mint 16 Mate with Thunderbird for email and Libre Office for documents, it feels a lot faster now and, much to my surprise, she had no problems with it being 'different'. Obviously this won't suit everyone but looks like a reasonable solution that involved no financial outlay. Due to the speed improvement she won't be missing XP.
Re: XP Advice
10-01-2014 9:36 AM
Re: XP Advice
10-01-2014 9:59 AM
Some older PC's have integrated network drivers which are ONLY for XP - and they have no win7 drivers available.
If you wanted to upgrade to win7/8 whatever on these you would need to put in a standalone network card into the PC
