Wiring required fot new installation
Fixes: 472
Re: Wiring required fot new installation
@WeeLassie
Thank you for the feedback. You know where to come if you have problems in the future.
Fixes: 109
@WeeLassie
Just as an additional thought - if you're happy lifting floor boards at the moment then you could get an electrician in to run Ethernet cable through the house as required.
shutter
Fixes: 67
@WeeLassie  So..... you had a cheap run on the chocky bikkies, and tea, then  ?   ? ?? ??
