Windows XP Prof. update removes option for access to BIOS.
- Windows XP Prof. update removes option for access ...
Re: Windows XP Prof. update removes option for access to BIOS.
16-08-2013 3:30 PM
Quote from: colintivy This has happened after a batch of updates recently came along which appear to modify a lot of eye candy amongst other things.
updates do not modify the look of your desktop unless a graphics update goes wrong and changes the screen resolution. And what happens before Windows starts to load is not under the control of Windows. So I strongly suspect that Colintivy has more clues available than he has yet written about.
16-08-2013 6:22 PM
Maybe try connecting the monitor to the onboard graphics output to get to the BIOS?
16-08-2013 6:40 PM
16-08-2013 7:21 PM
Quote from: colintivy I have recently become aware that my old Dell OptiPlex GX 110 desktop no longer flashes up the Dell logo and the option to access the BIOS set-up using F2 ................
This is a boot problem and nothing to do with Windows. Updates to Windows do NOT address functions reserved in the BIOS.
Either the machine is in sleep mode, or the BIOS has been corrupted and needs resetting!
I am running a Dell with 2 monitors and both display the Dell splash screen and all BIOS messages!
Some of the suggestions here just beggar belief!
York.
17-08-2013 10:38 AM
17-08-2013 11:50 AM
The BIOS output is probably being displayed on the PCI graphics card assuming the "Primary Video Controller" BIOS setting is set to Auto.
[quote author="Optiplex GX110 User's Guide"]Primary Video Controller determines which video controller to use when the system boots. When Auto is selected, the system uses a video
expansion card, if one is installed, or the onboard video controller if a video expansion card is not installed. When Onboard is selected, the
system uses the onboard video controller even if a video expansion card is installed.
17-08-2013 12:07 PM
17-08-2013 12:37 PM
17-08-2013 1:11 PM
I'm running a Dell with two monitors - they both display boot up messages including the splash screen. Have you got a Dell with two monitors?
Quote The machine is still running the original graphics system, the new card is in place but not actually used, this has been the case for some some time without any problem.
York.
17-08-2013 1:12 PM
I have now set the Video to On-board and everything works as before. Part of the original Dell information recommended me to check that video buffer is set to 8 MB, where do I find that?
17-08-2013 2:29 PM
17-08-2013 4:22 PM
Quote from: NedLudd Have you got a Dell with two monitors?
Have you got a Dell that dates from about the year 2000, that you've recently added a PCI (not PCIe) graphics card to?
18-08-2013 12:19 PM
The Dell is around that date and I have the new card installed PCI.
The first check should have been your idea (#22) of me putting the monitor on to the Geeforce card which would have revealed all and I would then been able to change the BIOS selection to On-board with ease and most of this thread would not have arisen. As a side effect, the new card got to displaying the Windows logo but then stopped dead. I guess that could be due to a lack of a driver which was reported when I tried to install the video disk that came with the card although the card was specifically labelled for XP. I will look at that later.
Thanks to all the worried brows that this has generated.
18-08-2013 12:36 PM
Every GeForce card that I remember sticking into Windows PCs (as an upgrade to the on-board graphics), as far as I remember loaded some default video driver with a low screen resolution, and then doing a reboot and a "Windows Update" advanced scan would highlight the latest Nvidia driver to install in the hardware driver section. Job done.
18-08-2013 12:45 PM
