Windows Live et al
shutter
Fixes: 65
Windows Live et al
Going further down on my Absolute Uninstaller listings... ( see D3DX10 thread )... I find a load of Windows Live stuff, that I do not want, never asked for,  (unless via "updates" and I did not know what they were! )  and won`t ever use,
They are all dated 6 December 2012  as for the D3DX10
so I would like to  "uninstall them"... will they come back again automatically? ? ? ?
2 REPLIES 2
rongtw
Fixes: 12
Re: Windows Live et al
should be fine to uninstall them if you dont need them , like me i uninstall all windows live stuff  Cool
shutter
Fixes: 65
OK.. Thanks... will try to remember not to re-install them next time I`m asked ! !  Embarrassed
