Windows Live et al
- Re: Windows Live et al
Windows Live et al
17-12-2012 11:46 AM
Going further down on my Absolute Uninstaller listings... ( see D3DX10 thread )... I find a load of Windows Live stuff, that I do not want, never asked for, (unless via "updates" and I did not know what they were! ) and won`t ever use,
They are all dated 6 December 2012 as for the D3DX10
so I would like to "uninstall them"... will they come back again automatically? ? ? ?
2 REPLIES 2
17-12-2012 5:42 PM
should be fine to uninstall them if you dont need them , like me i uninstall all windows live stuff
17-12-2012 7:37 PM
OK.. Thanks... will try to remember not to re-install them next time I`m asked ! !
