WinPcap.... what is it ?,,,,,, Do I need it ? ? ?
shutter
Fixes: 67
Whilst using the Control Panel > programs and features bit... to do an uninstall, I noticed a program called WinPcap...
I have no idea what it is, nor where it came from.... so any ideas....?
Here is what a quick google came up with.....
WinPcap is the industry-standard tool for link-layer network access in Windows environments: it allows applications to capture and transmit network packets bypassing the protocol stack, ...........etc etc etc etc......................,
I don`t do "network" stuff, apart from the normal surfing the internet, and emails.....
so do I need it.... and is it safe to unistall it, if I don`t.....?
12 REPLIES 12
jelv
Fixes: 10
Re: WinPcap.... what is it ?,,,,,, Do I need it ? ? ?
Wireshark!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
shutter
Fixes: 67
@Jelv.... you may just as well post  "cabbages"   for all the use that posting has to me...... Roll_eyes
jelv
Fixes: 10
Have you ever installed Wireshark?
shutter
Fixes: 67
No. Why should I..... what is it for..... is it necessary.... I haven`t installed google chrome... is that ok? I haven`t installed picasa either.... but I know what they do.... and I think they are unnecessary... so I haven`t installed them... Oh and another thing I haven`t installed is Skype... again... I know what it does,... but it isn`t necessary.. so I haven`t installed it... get my drift?  Undecided
jelv
Fixes: 10
http://community.plus.net/library/faults/using-wireshark-for-data-capture/
I wondered if you'd installed this when you were having speed issues - it's used for checking that traffic has been put in to the correct queue.
Wireshark requires WinPCap and this is the most obvious reason why you might have it installed.
shutter
Fixes: 67
Ha!... now I see what you are getting at......
No I haven`t installed wireshark..... the only thing I installed when I had speed issues, and also since my new hdd a couple of weeks ago... is Routerstats...
has it anything to do with that?
jelv
Fixes: 10
No, it won't be RouterStats.
shutter
Fixes: 67
So................. back to the original question then....
do I need it?  if not.... is it safe to uninstall it...?
  Undecided
jelv
Fixes: 10
I can't think what else it might be so I'd suggest removing it and see if anything stops working!
shutter
Fixes: 67
Thanks.  Wink
Here is a list of the programs that use "WinPcap"  http://www.winpcap.org/misc/links.htm#tools  -  do you recognize any of them ?
shutter
Fixes: 67
Thanks Purleigh..... Wink
none of them on that list apply to my setup.... and I have already uninstalled it...
