Wifi extender won't connect
GennyEMS
I have just switched to Plusnet from BT. my router Hub2 is upstairs in my office and I have been using an extender to boost the signal downstairs. This was a BT disc probably 6 or 7 years old now. It will not connect to the new router although I have followed all the various suggested ways of achieving that. Is it possible that the "old" BT disc is incompatible?
1 REPLY 1
Fixes: 246
Re: Wifi extender won't connect
Have you seen this - https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/td-p/1795292/page/11#:~:text=@....
