Distributing Data around Larger Properties.
Fixes: 480
In answering other posts I have been giving the options some consideration and for better or worse decided to post my thoughts here.
There are currently four ways of improving the distribution of Wi-Fi around properties, each has its strengths and weaknesses. These are:
  1. Ethernet cable.
  2. Powerline converters.
  3. Wireless extenders.
  4. Wireless Mesh Units.
Taking each in turn:
Ethernet cable.
By far the cheapest and most reliable method of getting the best possible distribution of data. Most router Ethernet ports are capable of data rates of up to 1Gbps (1000 Mbps). This speed can be connected to remote equipment with CAT5E cable lengths anything up to 100m so is more than enough for the vast majority of properties. Higher spec cable (CAT 6 and 7) are available but tend to be bulkier and rarely justified. There are two options here:
  1. All lengths of ready terminated cable are available from on line retailers. This can be hidden under carpets, tacked to skirting boards etc.
  2. With simple DIY skills it is practicable to buy lengths of unterminated cable and install it in a much more professional manner. As the cable is around 5mm diameter it is easy to drill through walls end hide the cable from sight. For example, I have cable runs that passes through built in wardrobes into the loft across the loft down through another built in wardrobe, through the ceiling down the back or a built in oven housing in the kitchen then through the wall into the hall where the Hub lives. Remember cable is cheap and as long as the length is less than 100m then circuitous routes are not an issue, it’s just a case of how much time and effort is put into hiding cable runs. Whilst plugs can be fitted to this cable it is much neater to fix a wall box and wire the cable to a socket. This can then be connected to devices with a short patch lead.
If Wi-Fi is required at the remote location then a Wireless Access Point can be located at the far end of the cable. These generally also include an Ethernet switch so that Ethernet can also be distributed from this point.
Powerline Converters.
These impose the Ethernet data onto the mains supply and distribute the data via the mains cabling. Due to background noise, the condition of mains wiring and the way the mains wire is distributed from the Consumer Unit can affect how well these work. This post gives an example of how these can perform in one particular property:  https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Powerline-Unit-Performance/m-p/1607450...
If these are used the password should be changed from the default. It is not unknown for neighbours to also have these devices with the same default password leading to cross connections.
If Wi-Fi is required at the remote location then there are Powerline devices with a remote unit that includes a wireless unit.
Wireless Extenders
This is a cheap and cheerful way of getting some improvement. When fitting these it is essential that there is a good wireless connection with the main router else their effectiveness is greatly diminished.
Wireless Mesh Units
With all wireless extenders it is normal practice for the router and remote unit to have different SSIDs in order to stop interference between the two wireless networks. This can be a great disadvantage with portable devices as they are moved between the best ranges of a wireless unit, frequently not automatically switching over to the better signal.
Mesh systems are the latest answer to this. They all transmit the same synchronised SSID so automatically connect to the strongest wireless signal. These however can suffer from the same problem as Wi-Fi extenders in that if there is a poor connection between say the base unit, which may either be a unit connected to the router or built into the router, and the next remote unit in the chain then wireless performance will be degraded. This can be rectified in many systems via an enhancement whereby the wireless units can be interconnected via an Ethernet cable ‘back haul’.
16 REPLIES 16
Nick100
Re: Distributing Data around Larger Properties.
Thanks for that useful summary of options.
I have just started with a plusnet hub 2 and have the same problem.
Previously I had a reasonable Wifi coverage using BT anywhere. I have a hardwired network with plenty of ethernet sockets and added 3 BT wifi discs to get coverage. Unfortunately the BT discs don't seem to want to work with the plusnet hub 2.
Is there a particular MESH device that you would recommend to connect to a wired network, that are compatible with the plusnet hub 2?
Fixes: 253
@Baldrick1
A really useful article (only just seen it due @Nick100 's comment!).
Ethernet wiring around the house - in many properties with plaster board on blobs, the cables can be dropped behind the plasterboard.  I did that for all of my phone extensions and TV aerial drops.  Not yet motivated to do similar for a data network.
WiFi extenders - is there a necessity for these to have separate SSIDs or is it just the way they set up as default?  It would be worth mentioning that these will rarely fulfil expectations as they need to use the WiFi bandwidth to "relay" traffic, effectively halving the WiFi speed.
WiFi AP - (either ethernet or Powerline connected) - I have remote WAPs and use the same SSID on everything so as to provide seamless roaming.  This can both work and be tricky, especially of the connected device has too much (or too little) "stickability" (Roaming Aggressiveness) to a WiFi SSID.  Another key distinction of APs over extenders is that APs generally act as routers providing a sub-network and DHCP service, which might keep local traffic off the back haul ... but that is getting a bit complex!
WiFi Mesh - what sets these apart from a collection of remote WAPs and specifically if using WiFi for the back haul a collection of inefficient WiFi extenders?
Fixes: 480
@Townman
I suspect that whether you can or cannot use the same SSID for extenders and WAPs are entirely dependant on the connected devices. If you can move seamlessly around a property with the same SSID it throws up another thought as to whether the two devices should use the same or different wireless channels? Back in 2020 when I produced the above post I felt that using separate SSIDs were the safest solution. I don’t know if the ‘stickiness’ is influenced by the SSID being the same or the channels used by the two devices? If they both have the same SSID and use the same wireless channel does that confuse devices?
 This begs the question as to whether it is worth the cost of mesh if simple extenders give seamless performance, unless of course that the mesh backhaul effectively doubles the bandwidth?
I confess I know very little about how mesh works. Does the backhaul need the same bandwidth as the ‘forward path’  (does it have a name?)? If so these mesh devices that use Powerline for the backhaul could be vulnerable to different circuit issues.
My current thinking is that the best solution for wireless at FTTP speed is mesh with an Ethernet backhaul.
Fixes: 253
Certainly the use of ethernet back haul leaves the full Wi-Fi bandwidth available for end-device to router connectivity, unshared with WiFi AP to router back haul necessity.
Fixes: 480
@Nick100
Sorry for getting diverted from your question. The Plusnet hub cannot be used as part of a mesh. If you are on fibre or fibre extra FTTC then you can set the Hub 2 to bridge modem mode and use it with any mesh router that allows a PPPoE connection. You will probably get as many recommendations as answered as that is about all. Alternatively you can use the Hub 2 as is with simply a mesh add on setup. I believe that BT sell a good value product that simply plugs in to one of the hub LAN sockets.
If you are on FTTP full fibre then you do not need a Hub 2. Simply buy a mesh router.
Fixes: 480
@Townman
I also assume that the Ethernet backhaul removes the need for there be a wireless connection between satellites.
retnartsl
Hi thank you for your reply I have an office in the garden with a Ethernet cable going to it as wanted to get Wi-Fi there and wondered what extenders are compatible please?
Fixes: 253
You do not need “extenders” if you have an Ethernet cable to the location you want WiFi.
You need a WiFi Access Point (router) which you attach to the end of the Ethernet cable. That can be a specific device for that purpose or the repurposing of an old WiFi router.
Technology names can be confusing - you have in your mind “extending WiFi coverage” but a WiFi extender is a specific technology solution which probably will not serve your needs best.
Gr3len
Thank you for this useful article. I have one question: I need to extend my connection to multiple areas of the property. I will use CAT5E cable as recommended. Can I daisy chain the WAPs with no loss of speed or should I directly cable each of them to the Plusnet Hub Two router?
Fixes: 253
If the WAPs have a second Ethernet port then that would work, however that would firmly fix the location of the WAPs.
What would be the total length?
Putting them all on one router port means they all share the 1GB channel.  That might not be proficient.  What works and what performs might not be the same with your approach.
Gr3len
Thanks. I'm thinking 25m and 50m.so 75m as a daisy chain or else I need to run 75 and 25 if run direct from the hub
Regarding the firm fixing - if I understand you correctly, you mean the placing of the 1st wasp would not be easily movable due to the wap2 dependency on it? If so, I was thinking that I would test the speed of the first one before deciding on it's final position.
I'm assuming that because the length is less than 100 m there would be no loss in Speed but that's one thing I'm unsure about.
Fixes: 253
You are correct on all points.
As for location, it’s not speed, but WiFi coverage.  The LAN connection will be 1Gbps, but you are NOT going to get that over WiFi
Your key considerations are the coverage across the three WiFi APs - router and 2x WAPs.  There is a tendency for the router being located on an outside wall near where the BT circuit enters the premises.  That is not proficient for WiFi coverage - consider the area of coverage to be a circle - half of it goes outside the building … usually not into “your space”.
Your need for coverage might be better served by moving the router into a more central location.  If you have FTTP that’s easier than if you don’t.  There’s lots of articles around here discussing that.
Putting both WAPs on the same router port does not change speed, but the capacity is shared between devices so effective data transfer rates might be impacted.
Gr3len
Ok, thanks. Based on what you say it makes sense for me to try the central location first. - as in place the hub in the hallway connected to the fttp via Ethernet cable and then experiment with this position to find the best location and then check speeds around the house to see where the struggle points are?
Maybe I was getting confused with using WAPs. If I find a weak signal to certain remote locations after going this, what do you suggest?
Fixes: 480
@Gr3len
There are many variations on Ethernet wiring layout. On a backhaul network that I have installed for a friend, cabling runs from the mesh master unit to a cupboard fairly central to the property, where I have installed a 5 port Ethernet switch. From here separate cables run to other parts of the property. This has given the option to additionally add another two Ethernet cables to other locations if necessary. These could be extra mesh satellites.
The switch provides buffering so I assume reduces any exceeding 100m concerns.
I understand @Townman’s comment regarding excessive data loading on a single link, but I assume that should only be a problem if you are moving large amounts of data around your local network. Under other circumstances, I assume that the 1Gbps backhaul would be compatible with an up to 900Mbps connection with the outside world.
