Wifi Direct
30FTTC06
Fixes: 4
Re: Wifi Direct
Does it matter, what do I gain other than interference from other stations around me ?
30FTTC06
Fixes: 4
Re: Wifi Direct
I'll end it right here.... the figures are showing using ch1,5 I'm loosing not gaining.
Connecting to host 192.168.0.33, port 5201
[  4] local 192.168.0.97 port 44504 connected to 192.168.0.33 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  9.25 MBytes  77.4 Mbits/sec
[  4]   1.00-2.01   sec  8.00 MBytes  66.9 Mbits/sec
[  4]   2.01-3.00   sec  13.0 MBytes   109 Mbits/sec
[  4]   3.00-4.00   sec  13.4 MBytes   112 Mbits/sec
[  4]   4.00-5.00   sec  12.6 MBytes   106 Mbits/sec
[  4]   5.00-6.01   sec  13.5 MBytes   112 Mbits/sec
[  4]   6.01-7.00   sec  13.5 MBytes   114 Mbits/sec
[  4]   7.00-8.00   sec  8.88 MBytes  74.2 Mbits/sec
[  4]   8.00-9.01   sec  11.9 MBytes  98.9 Mbits/sec
[  4]   9.01-10.00  sec  14.6 MBytes   124 Mbits/sec
[  4]   0.00-10.00  sec   119 MBytes  99.5 Mbits/sec                  sender
[  4]   0.00-10.00  sec   119 MBytes  99.4 Mbits/sec                  receiver
iperf Done.
Reverse mode, remote host 192.168.0.33 is sending
[  4] local 192.168.0.97 port 44510 connected to 192.168.0.33 port 5201
[  4]   0.00-1.00   sec  12.6 MBytes   105 Mbits/sec
[  4]   1.00-2.00   sec  16.6 MBytes   140 Mbits/sec
[  4]   2.00-3.00   sec  16.4 MBytes   137 Mbits/sec
[  4]   3.00-4.00   sec  11.0 MBytes  92.5 Mbits/sec
[  4]   4.00-5.00   sec  10.8 MBytes  90.7 Mbits/sec
[  4]   5.00-6.00   sec  13.2 MBytes   111 Mbits/sec
[  4]   6.00-7.00   sec  12.9 MBytes   108 Mbits/sec
[  4]   7.00-8.00   sec  12.3 MBytes   103 Mbits/sec
[  4]   8.00-9.00   sec  12.6 MBytes   105 Mbits/sec
[  4]   9.00-10.00  sec  12.4 MBytes   104 Mbits/sec
[  4]   0.00-10.00  sec   131 MBytes   110 Mbits/sec                  sender
[  4]   0.00-10.00  sec   131 MBytes   110 Mbits/sec                  receiver
iperf Done.
30FTTC06
Fixes: 4
Re: Wifi Direct
And now back to 8,4
[  4] local 192.168.0.97 port 44716 connected to 192.168.0.33 port 5201
[  4]   0.00-1.00   sec  10.8 MBytes  90.0 Mbits/sec
[  4]   1.00-2.01   sec  15.6 MBytes   131 Mbits/sec
[  4]   2.01-3.00   sec  17.1 MBytes   144 Mbits/sec
[  4]   3.00-4.01   sec  17.8 MBytes   149 Mbits/sec
[  4]   4.01-5.00   sec  17.8 MBytes   150 Mbits/sec
[  4]   5.00-6.00   sec  17.8 MBytes   149 Mbits/sec
[  4]   6.00-7.01   sec  17.1 MBytes   143 Mbits/sec
[  4]   7.01-8.00   sec  16.8 MBytes   141 Mbits/sec
[  4]   8.00-9.00   sec  17.9 MBytes   150 Mbits/sec
[  4]   9.00-10.01  sec  17.4 MBytes   145 Mbits/sec
[  4]   0.00-10.01  sec   166 MBytes   139 Mbits/sec                  sender
[  4]   0.00-10.01  sec   166 MBytes   139 Mbits/sec                  receiver
iperf Done.
[  4] local 192.168.0.97 port 44722 connected to 192.168.0.33 port 5201
[  4]   0.00-1.00   sec  21.2 MBytes   177 Mbits/sec
[  4]   1.00-2.00   sec  21.1 MBytes   177 Mbits/sec
[  4]   2.00-3.00   sec  20.5 MBytes   172 Mbits/sec
[  4]   3.00-4.00   sec  21.6 MBytes   181 Mbits/sec
[  4]   4.00-5.00   sec  21.4 MBytes   179 Mbits/sec
[  4]   5.00-6.00   sec  21.0 MBytes   176 Mbits/sec
[  4]   6.00-7.00   sec  21.6 MBytes   181 Mbits/sec
[  4]   7.00-8.00   sec  21.2 MBytes   178 Mbits/sec
[  4]   8.00-9.00   sec  21.2 MBytes   178 Mbits/sec
[  4]   9.00-10.00  sec  21.0 MBytes   176 Mbits/sec
[  4]   0.00-10.00  sec   212 MBytes   178 Mbits/sec                  sender
[  4]   0.00-10.00  sec   212 MBytes   178 Mbits/sec                  receiver
iperf Done.
ejs
Aspiring Hero
Fixes: 25
Re: Wifi Direct
And those speedtests are representative of all times and all amounts of traffic on other channels?
You're right, the choice of channel does not matter, and neither does a speedtest result. Just pick any number you like with no regard for anything else.
30FTTC06
Fixes: 4
Re: Wifi Direct
So why do people even tell others to try another ch then @ejs eh... lordy lord.
Thats what works best for me, I don't see why I need to waste any more time trying to show my point of view with YES repeatable results from my point of view of course.
Edit: To be clear.
"Does it matter" Does it matter where I < put my > WiFi if that is what works best for me!
