Wi Fi dead zone fix
rheno
Wi Fi dead zone fix
Hi all.
So i have bought two TP link Wi Fi cctv cameras,
one works great in the rear of the property, the other in the front of the property does not, it is in a  Wi Fi  dead zone, according to the tp link app, so i bought a tp link Wi Fi extender, this barely worked in the dead zone but at the same time it reduced Wi Fi in the rear thus making the rear camera inoperative, so thats gone back to argos.
Any way to improve Wi Fi coverage without an extender please ?
Thanks in advance
4 REPLIES 4
Gel
Champion
Fixes: 29
Re: Wi Fi dead zone fix
Fixes: 118
@rheno
What type of connection are you on and is there any chance of running ethernet cable to the location?
rheno
What type of connection are you on , i have no idea, how would i find out please?
and is there any chance of running ethernet cable to the location?  probably need around 10 meters and floorboards up, so no not at the moment
Fixes: 118
@rheno
I was wondering if you were on Full Fibre but I suspect you'd know if you were. You can log into your Members page and check the name of the contracted product if your wish.
If It had been full fibre then it can sometimes be worthing laying ethernet cable as it's future proof.
I'm not familar with WiFi camaras - are they battery or mains powered?
