Chromebook problem
Smith7
All Star
Chromebook problem
I have just purchased a Lenovo Chromebook with a 8GB ram
It is very quick and I am very pleased with it apart from the speaker volume is very low/poor
I have checked the speaker setting by clicking on the time in the BRHS and everything looks OK the speakers on are full
Any Chromebook users have any ideas
6 REPLIES 6
shutter
Fixes: 67
Re: Chromebook problem
@Smith7  Not an answer to solve your internal speaker volume problem, But..
have a look at this item on ebay.
eBay item number:405102646470
And search for  "Laptop External Speakers"
PowerLee
The speakers on the work Panasonic Toughbook CF20 are pretty rubbish - I use an Anker Soundcore 2 bluetooth speaker when I need to use the sound.
Plenty of available options for eternal speakers.
No longer a Plusnet customer due to Openreach incompetence - Moved to Zen via CityFibre for symmetrical 500Mbps fibre broadband & digital voice.
Mav
Fixes: 518
Moderator's note(s):
Thread moved from General Chat to Tech Help.
Forum Moderator and Customer
Smith7
All Star
Update just spoken to the Lenovo helpline
The speakers are only 2 watts so that's the problem
When I use the headphones it's very loud and I have to reduce the volume on them
Will have to try the external speakers that was suggested
Smith7
All Star
Problem solved borrowed a Jamjar worked perfectly
shutter
Fixes: 67
@Smith7   Surely you needed 2 jamjars, for stereo output  ? ? ? ?
As for headphones.... I can recommend ONE ODIO
https://www.ebay.co.uk/sch/i.html?_nkw=oneodio+a70+bluetooth+headphones&_sacat=0&_from=R40&_sop=15&L...
