Why does this site object to Adblock and Adblock Plus on Win 7 but not on Win 10
- Re: Why does this site object to Adblock and Adblo...
05-09-2017 8:21 PM - edited 05-09-2017 9:34 PM
http://www.bournemouthecho.co.uk/
I can't see any difference in the settings using Firefox 55.03 32 bit
Re: Why does this site object to Adblock and Adblock Plus on Win 7 but not on Win 10
05-09-2017 9:09 PM
It doesn't like Adblock Latitude in Pale Moon X64 running under Windows 10 build 16353.1000
05-09-2017 9:36 PM
Just to add - and I need to check in the morning - I think that the Win 7 machine may be using the 64 bit version of Firefox
06-09-2017 12:39 PM
Tried 32 bit version and the same result so it must be something to do with how Windows 10 handles it
06-09-2017 12:51 PM
I think I have isolated the problem
Disabling javascript sorts it so I assume it is something to do with how Windows 10 handles javascript as compared to Windows 7
06-09-2017 1:12 PM
using windows 10 64bit at home - tested site no complaint about ablock.
i use uBlock Origin though (which is far superior to either Adblock or Adblock Plus IMO)
06-09-2017 2:41 PM - edited 06-09-2017 2:54 PM
installed YesScript and blacklisted the site which sorted it
will try Ublock Origin and see how that copes
EDIT
Confirmed that also sorted it so will stick with that for the time being
UPDATE
Checked using YesScript and it blocked the comments being read so not an option
13-09-2017 9:18 PM
Interesting thing from Ublock Origin - following a link from Google Shopping search
13-09-2017 9:33 PM
googleadservices is used for ads and is also used when linking from google shopping links.
just click on temprarily and it'll send you to the original page.
13-09-2017 9:41 PM
better still go to the site and not via Google Shopping
