Who's 21CN list should we believe?
mgillespie
Plusnet's doesn't list my exchange (which DID have a date of March 2011, which was then removed), now Plusnet's checker does not list it at all.  However Samknows and Kitz both show a 21CN(WBC) RFS date of March 2012
http://www.samknows.com/broadband/exchange/STPRSTN
So who should I believe?  is the Plusnet data upto date?  (I would hope so with their ties to BT).
What do I need to do in march to get an ADSl2+ connection?  Anything?
BRABUS
Re: Who's 21CN list should we believe?
Personally I don't believe any of them anymore.  My exchange was more like a flashing light,  It was on the list, it was off the list etc etc.  Now its not on a list and no one from any organistation can give any believable answer.
Cross your fingers and hope - thats what I have resorted to  Cheesy
As things can be rather volatile the best advice is to check fairly regularly, a good 'official' place being here: http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Call me 'w23'
BRABUS
Thanks but that tells us what we already have, not what we are going to get nor when Sad
Fixes: 188
That implies there are no upgrades due in the relatively near future.
My line has ADSL Max and that's it but I now live in hope after reading this recently updated spreadsheet from BTW. Smiley
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
mgillespie
Thanks, that spreadsheet also shows my Exchange being ADSL2+ sometime in march.  So it's just Plusnet's thats wrong...
Next question, do I need to do anything to get it, or will it just happen, one day I get better speeds?  (my router is ADSL2+ enabled).
pierre_pierre
eventually you would get it, first a switch from 20CN to 21CN, much later you should be put on ADSL2+.
if you synch speed is over 5000, and you notice that your exchange has switched,  ask here and you should be on within 10 days
