What speed is needed
frenchman23
Hi There
My son is getting his first broadband and wants to know what speed package to look for.
I must admit, providers seem to show the speed in different ways, some show Mbps and others say eg 50mb
18 REPLIES 18
Fixes: 118
Re: What speed is needed
@frenchman23
The first question is - what service is available? Is it Full Fibre or what's known as Fibre (old school FTTC without the phone element)?
Second question is what's he going to be using it for?
frenchman23
Hi
he has full fibre in his road and he watches some you tube films and does some searching on the net if that helps
Fixes: 118
@frenchman23
Full Fibre means he has a choice of speeds unlike Fibre.
Sounds like he doesn't need high speed so something like FF74 or FF150 could well do the trick - these are the two lowest speeds available on Full Fibre.
You can upgrade speed at any time by taking out a new contract but to reduce speed you can only really do it at contract renewal.
frenchman23
I have a d/l speed of 38, is that decent, I watch the odd film or morning tv ?
George
Fixes: 118
@frenchman23
If it suits your needs then it's fine but is only a reasonable speed when compared to what some can receive while they wait for Full Fibre.
Your son will get near double your speed at a minimum.
frenchman23
So why dont I have double as I have full fibre 145 ?
George
Fixes: 118
@frenchman23
I'm guessing you tested on WiFi
Can you run a speed test using a wired connection?
Fixes: 392
How are you measuring your speed? On a device connected by Ethernet, or wirelessly some distance away from the router, with intervening walls - especially if foil insulation is involved, @frenchman23 ?
frenchman23
My router is downstairs and I did the test on Plusnet website.
George
Fixes: 392
So, how far from the router were you, and was it a ired or wireless test? The only valid tests are wired.
Fixes: 118
@frenchman23
The likelyhood is you're received the expected speed at the Router but have a WiFi issue resulting in lower speeds noted. A wired test is the only way to be certain.
You could try logging into the Router ADmin, going to Advanced settings and turning of one of the WiFi bands (depending on which one your laptop uses). Then test your speed again.
markhawkin
Champion
Fixes: 22
@frenchman23
In the absence of anything that drives a known requirement for a faster speed, the "around" 150Mb/s full fibre options will do for many users and most of the speed will (typically) be available via WiFi.
It's worth noting that not all networks are equal. Some suffer congestion more than others.
From personal experience I've found Plusnet good. Some of the slightly cheaper options seem (from experiences I'm aware of) sometimes less good.
Shop around as there are some good "new customer" offers on the comparison sites. It's well worth comparing the comparison sites!
Champnet
Fixes: 21
A lot depends on how many people are using the internet and their ages..............
I would also note that it's not all about download speeds, if you have multiple devices with cloud saves a consideration needs to be made for the associated upload speed for the chosen product
Currently plusnet offer Full Fibe 74 with 20 Mbps download for £1 extra Full Fibre 150 with 30 Mbps download.
With regards to turning off WiFi bands on the Hub, this could cause more problems than it resolves, although 5GHz band gives faster connection speed, at distance 2.4 GHz might be faster. Some devices only use 2.4GHz band so they would be rendered useless with the Hubs 2.4 GHz band tuned off.
