Weird Linux problem
shutter
Fixes: 67
Weird Linux problem
Linux Mint 20.2 MATE
I have had this before... but .... as usual... cannot remember how I solved it.....
When I click the LM  ( menu ) logo bottome left... to get the menu list up.   and then select Desktop.... I get  Irfanview playing a music video that is on the desktop.
If click on "Home Folder"   it just get a blank Irfanview screen...
( Irfanview is a picture viewing and editing software running on WINE - kinda like GIMP )
If I click on Desktop from the "Computer" ... it shows the desktop files and folders ... as expected ...
I have unistalled Irfanview,... and re-booted the laptop.... but when I now click on Desktop... I get a message box... Windows is unable to open this.
On reinstalling Irfanveiw... it , again, shows the music video.
Have moved the "offending" music video to the Music folder... and now... when I click Desktop... I get a different item from the desktop ( actually a gif video) playing on Irfanview.
Any ideas ?  something to do with properties methinks but don`t know how to change it .
28 REPLIES 28
VileReynard
Fixes: 20
Re: Weird Linux problem
Is this problem restricted to when running Wine?
shutter
Fixes: 67
@VileReynard  Dunno,  I need to use WINE for lots of programs that I use. 1, because I am so familiar using them, and 2, because there is no suitable equivalent in the Software Manager listings. ( so I am not going to dump wine ).
This problem just "happened"... got no idea what started it...  .. It`s more of an inconvenience than a serious problem... as I can access the "desktop" files and folders/directories by clicking on "Computer"... then on "Desktop" to show the listing.
VileReynard
Fixes: 20
Can you still run the many good Linux programs - Wine is not the answer for everything.
Also, are you getting (and applying) security updates successfully?
shutter
Fixes: 67
@VileReynard   I know you don`t like using WINE... so your "prejudice" is accepted... however.. I DO, and I  get ALL the UPDATES and my machine is now running MINT 20.3 ( recent up date 2 days ago ) .. also :WINE was updated about 2 weeks ago to version 7 .0 as an "official" synaptic update in the normal process of updates.
There has never been any problem applying any updates.  ( I have been using MINT since version 8, and Wine since version 3.0  without any problems )
Yes I can still run the many good Linux programs, and have several from the "software manager" .
VileReynard
Fixes: 20
That's great - hope you get the Irfanview thing fixed.
shutter
Fixes: 67
Yeah....So do I...   Strange though..... Wink
shutter
Fixes: 67
@VileReynard
Just to put your mind at rest, regarding WINE.... I have another laptop, running the same setup as this one... i.e. it was on Mint 20.2   then upgraded to Mint 20.3 with WINE 6 updated to WINE 7.0  and all the same programs installed.
I have just upgraded the 2nd laptop from Mint20.2 to 20.3,.....  and WINE 6 to WINE 7.0
the problem described in the original post does not happen on the 2nd laptop.
And so, I do not think it is associated with WINE ( either 6 or 7 )
Fixes: 387
@shutter This might sound a daft idea (some of mine do), but if the setup on both machines is identical, could you not wipe the problematic one and copy the data from the one which is OK? Don't know enough about Linux to know if that would work, though.
shutter
Fixes: 67
@jab1  Yeah... tis possible... can do a clone.... except ! ! ! .. ( always an exception to the rule) .
this machine ( the one with the problem ) is the main machine... so all my recent work is on this HDD/SSD
The 2nd machine is more a "holiday use" machine, as it is only 11 inch screen... so easier to pack up and take away.
If it were a "major" problem, I could just as easily wipe the hdd/ssd and re-install Linux Mint 20.3 as a new install, and then rebuild it all... but it`s more of a "niggle" that has appeared for no reason that I can think of..
I vaguely remember it happening ( or something similar ) a while back, but can`t remember  a) what caused it or b) how I fixed it ! ! ..
Fixes: 387
OK , just a suggestion, but I see your point.
RPMozley
Seasoned Pro
Fixes: 18
What is the Desktop menu option supposed to show i.e. what are you expecting to get?
Menu libre is the app to edit menus on ubuntu - not sure what Mint uses.
That's RPM to you!!
shutter
Fixes: 67
@RPMozley  The same as if you go to "Computer > Desktop  "   shows all the stuff I have on my desktop.. (its got all my shortcuts on there,)
It was just the easiest way to find what program I wanted to use.  now it takes two more clicks to get to the same place !
But... it should not go to showing something running on another program... instead of showing the contents of the Desktop..
RPMozley
Seasoned Pro
Fixes: 18
So ideally you want to open a file manager with the correct folder of “desktop” showing.
After a quick look about Mate, is the desktop link you are describing under “Places” menu item?
That's RPM to you!!
shutter
Fixes: 67
@RPMozley
Yes... that`s right.....
