WebGL1 &2 disabled or unavailable
shutter
Fixes: 67
As my previous thread about PREY seemed to disintegrate, with no answers from my beloved followers/helpers....
nor any response from PREY themselves... (most disappointing) ..(unless they don`t work over the weekend  ? ? ?  Maybe an answer tomorrow)
Anyway... on small 10 inch Hannspree laptop... (which has the same OS and progs as the DELL 15 inch laptop. ) I get a message saying the map cannot be displayed because (map displays ok on the Dell 15 inch) ...
WebGL 1 and WebGL2 are disabled or unavailable.
Sometimes this is the result of older video drivers being rejected by the browser. try updating your video drivers if possible
Also check out Get WebGL, or try installing the latest version of Chrome, or Firefox
Firefox is "up to date".. latest version installed.
Going into Firefox Preferences page..
under the section ... Performance,
It shows Use recommended Performance Settings.. ( tick in the box)
but nothing about the hardware acceleration ,
until I remove the tick in the box... then it says
Use hardware acceleration when available.
content process limit      8 (default)
Either way... (Tick in first box or not ticked) the map does not show..  ...##
The little sticker on the laptop says "Intel Atom" inside !... so I looked for INTEL Video driver update, but drew a blank on that.
I have run "sudo apt update" and it does not report any updates needed.. ( recent downloaded updates also installed ).
Going to "Driver Manager" ( as superuser)   it shows a blank panel, and the words  "No proprietary drivers are in use" .. which is as helpful as a chocolate fire guard...
Going to the Firefox section on Troubleshoot ... for the Graphics section, it says  ( under the FEATURES)
Compositing Basic
WebGL1 Driver Rendererer           WebGL creation failed:
*Refused to create native OpenGL content because of blacklist entry :
FEATURE_FAILURE_OPENGL_1
*Exhausted GL driver options.
WebGL2 Driver Renderer  WebGLcreation failed.. ( as above )
GPU#1
Active                   Yes
Description           Intel Open Source Technology Centre - Mesa DRI Intel(R)Pineview M
Driver ID              Mesa DRI Intel(R) Pineview M
Driver Version      1.4 Mesa 19.0.2
Decision Log
HW_COMPOSITING                blocked by default : Acceleration blocked by platform
OPENGL_COMPOSITING       unavailable by default:  Hardware compositing is disabled
WEBRENDER                          opt-in by default:  WebRender is an opt-in feature
                                                 unavailable by runtime: Hardware compositing is disabled
WEBRENDER_QUALIFIED     blocked by env: no qualified hardware
Haven`t a clue what all that means individually or collectively...
However, it seems that since the machine was originally sold with Windows 7 starter installed... and now it has LINUX MINT 19.1 on it.. there is some difficulty updating drivers.
( same on the DELL 15 inch..  going to the Dell site and entering the Service number  to access the updated drivers results in a "no show"  due to the change of O.S.)
So, once again... I am in a quandry and don`t know the way forward to solve the problem.... any help,.... much appreciated ... as always.
7 REPLIES 7
RPMozley
Seasoned Pro
Fixes: 18
Re: WebGL1 &2 disabled or unavailable
What about this article? https://www.binarytides.com/enable-webgl-firefox-ubuntu/
That's RPM to you!!
shutter
Fixes: 67
@RPMozley
I read through that... did some terminal work...the first bit.... it said.. it was already installed.
couldnt find it  in "about:config" list..
skipped the last bit before this...
Test it
Now open the following url
http://get.webgl.org/
Clicked on the link and got the revolving cube  saying that the browser DOES support webgl..
CRAZY or what... !    still none the wiser... Crazy3
RPMozley
Seasoned Pro
Fixes: 18
It’s installed on the system, that’s a good start. Next is trying to locate where it is, not always easy to do. Is there a file search program installed in Mint? For Xubuntu the program is called “Catfish Search”.
That option within Firefox may not be there by default so you will have to add it manually. I think it can be added within Firefox on the config page, right click probably.
That's RPM to you!!
RPMozley
Seasoned Pro
Fixes: 18
Scratch that, maybe it is just the particular site you’re using that’s at fault, if it’s working fine on other pages.
That's RPM to you!!
mikelahey
Fixes: 12
It's probably because Linux is using a generic driver to drive the Intel display adaptor, therefore there is no 3D hardware acceleration for OpenGL support as these require hardware specific drivers.
mikelahey
Fixes: 12
A bit of detective work on the Intel website and  I reckon your GPU is probably an Intel GMA 3150,
https://www.intel.co.uk/content/www/uk/en/support/articles/000005526/graphics-drivers.html
You could try this package:
apt-get install cedarview-drm libva-cedarview-vaapi-driver cedarview-graphics-drivers
See: https://www.linuxquestions.org/questions/linux-general-1/intel-graphics-media-accelerator-3150-a-944...
shutter
Fixes: 67
@mikelahey  Thanks for your input... and investigations... I will have a look and see what those links say, and see if I can do something with them
Wink
