Watching Telly on my Laptop
FIXED- Subscribe to RSS Feed
- Re: Watching Telly on my Laptop
21-07-2021 12:51 PM
We are not into... telly via the phone line... or ... satellite telly... we have FREEVIEW (free to air) through an aerial on the chimney. ... It serves our purposes "indoors"..
What I would like to be able to do, is... especially on days like today... take my laptop outside in the garden, to a shady spot. and watch telly there...
I can watch about 14 German T.V. Stations on-line.. ( with a VPN)... I can watch a few French T.V.stations on-line.. I could also find numerous other countries national T.V. on line...but I cannot find any UK terrestrial TV live, on line.
which is annoying when you think about it !. Pity I don`t understand German.. or French. or any other language, ..
Anyone got any ideas on how to get FREVIEW/Terrestrial UK t.v. viewable via WIFI on my laptop outdoors ? ? ? Preferably independent of the existing telly in the lounge, which the missus will be watching her favourite progs on ! .
Fixed! Go to the fix.
21-07-2021 12:58 PM - edited 21-07-2021 12:58 PM
@shutter
I think you can go into TV Guide Freeview and watch on a laptop by clicking on a programme
You have to log in
https://www.freeview.co.uk/tv-guide
Let us know if it works
HD
21-07-2021 1:39 PM
@Anonymous Thanks for that.... just done a quick look about.. it seems that if you click on the red circle with a red sideways triangle
You are then offered the program info fly out...
Then you have to click on the "watch now" icon...
and then you have to "register" or "log-in" to that particular station...
So.. if I want to channel hop, I will have to "Register" and "log-in" to about 20 different channels/stations and remember the "Log-in" for every one of them, every time I want to change channel...
cos I tried BBC1.. and it offered that... and said.. why do I need to register with BBC.. ( so presume ITV is the same.. and Yesterday is UK TV... etc etc etc ) .
Unless... of course.. someone can tell me different...
21-07-2021 1:42 PM - edited 21-07-2021 1:54 PM
It'll cost some money but what you need is a Freeview DVB-T HD TV Tuner you can buy them on Amazon or Fleabay of course, just make sure you get the right one.
21-07-2021 1:47 PM
Hi @Mook Got two of them... tried to use them for my Amateur Radio listening...but can` t seem to get them to work at all.... as for getting TV on the tiny micro/mini antenna supplied... I doubt it....
we are "over the hill" from the Main transmitter on the Isle of Wight.. and our tv sig is showing 70 percent on the tuner on the telly... with a "proper" aerial on the chimney..
21-07-2021 1:48 PM
If you don't want to log in to the net then the other option is a receiver that plugs in to your laptop. A Google search for Freeview Receiver Dongle will throw up all sorts. Whether one will work with Mint or through Wine is the question though?
21-07-2021 1:57 PM
Maybe time to give them another try. Where you are uou should be able to get Freeview with a wet bit of string never mind a roof aerial.
21-07-2021 1:58 PM
You can stream live or catch-up on BBC iPlayer and the ITV Hub. I think Ch 4 have something similar. Ch 5 is catch-up only.
If you've saved the password in FF you don't need to keep logging in. I assume other browsers have similar.
Zen SOGEA 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
21-07-2021 2:03 PM
@Baldrick1 That is what @Mook was advocating...
As an experiment.... ( see my orignal answer to @Mook ) I chopped off the aerial lead, and made an adapter plug to plug it in to my HF and VHF aerials, as well as the TV aerial, on the chimney.. but still no reception
It also depends on certain software being installed to make the HF section active.
21-07-2021 2:04 PM - edited 21-07-2021 2:06 PM
There are some special managers specials direct from Humax at good prices
I have purchased direct from them before and have been pleased with the deals
Humax no longer make freesat boxes where you use a dish
https://www.humaxdirect.co.uk/special-offers.html
HD
21-07-2021 2:20 PM
Sorry @shutter but what do you expect when you only pay 10 for a piece of 💩like that and it no doubt source from fleaBay too.
21-07-2021 2:22 PM
@Mook Nah... that was just a pic that I found....
I think the two that I bought a few years ago, were about £25 each...
(same sort of thing though) !
21-07-2021 2:33 PM
Well that's what I'd consider paying myself if wanted one but disappointed to find that they wouldn't work.
21-07-2021 2:59 PM
@Anonymous Yeah.. but... I don`t want another "box" to carry about with me.. (would probably need the mains for power, too ! ! ! ) ..
The dongle idea would be great... if it worked...but alas.. it does not.. ( just dug out my two dongles, and despite me running WINE with Linux Mint 20.1 they do not seem to be "compatible" with the system... so a total failure with the driver/install discs too ! .
ah well.... case closed. then ! ![]()
21-07-2021 3:22 PM
@shutter Don't close the case. Plug one in and let's see what errors you're getting.
