WPA2 Password Cracking in under 10 hours - WPS Side-channel attack
- Re: WPA2 Password Cracking in under 10 hours - WPS...
- « Previous
- 1
- 2
- Next »
Re: WPA2 Password Cracking in under 10 hours - WPS Side-channel attack
04-01-2012 11:30 PM
Yes it is. Technicolor own the Thomson Telecom brand.
David
16-02-2012 3:12 PM
Quote from: Kelly We ship all our technicolor routers with WPS off.
Does this survive a factory reset?
Product Name: TG585 v8
Software Release: 8.2.7.8
If not what is the WPS facility called and on which router management screen does it appear?
martin
martin
16-02-2012 3:39 PM
Hi Martin,
Yes, this does survive a factory reset. There is no web interface to enable WPS, you'll need to do this through the telnet interface. If you're interested then the command is:
:wireless wps config ssid_id=0 state=enabled
And if you change your mind, to disable then run this:
:wireless wps config ssid_id=0 state=disabled
dick:quote
dick:quote
16-02-2012 6:51 PM
Quote from: Matt Yes, this does survive a factory reset.
Good news!
Quote There is no web interface to enable WPS, you'll need to do this through the telnet interface.
OK.. 2 questions.
1. Is there a Telnet command to query the current status?
2. Any other usefulTelnet commands that are not available in the web interface?
PS The part of the web interface that confused me was on the Wireless config page.
The item is called "Allow New Devices:".
The options are "New stations not allowed", "New stations are allowed (via registration)", or "New stations are allowed (automatically)"
I wondered if this was WPS.
martin
martin
16-02-2012 7:43 PM
If you telnet into the router and do
wireless wps config
(without the state= parameter) it will tell you the current state (eg WPS disabled)
After enabling it I think you need to do
saveall
to ensure the changed setting survives reboot.
wireless wps config
saveall
David
16-02-2012 7:50 PM
Do you know anyone who wants to sit outside your house for 10 hours, so they can intercept your valuable traffic?
Excess of paranoia...
16-02-2012 10:07 PM
Quote from: A Do you know anyone who wants to sit outside your house for 10 hours, so they can intercept your valuable traffic?
No, but I guess if anyone did want to I would not know them.
Quote Excess of paranoia...
No, excess of curiosity about how things work.
martin
martin
- « Previous
- 1
- 2
- Next »
