WMV onto iPhone
Fixes: 135
WMV onto iPhone
Has anyone a foolproof method of getting video files onto an iPhone such as WMV or AVI.
When I had a proper phone I could just drag and drop but this thing is a bastard Angry
BTW the files are off my video camera.
Customer and Forum Moderator.
barky
Re: WMV onto iPhone
try Format Factory
http://www.pcfreetime.com/
in the video section select mobile device then apple iphone & ipod then video size .... should work if you have video files on your hard drive
Re: WMV onto iPhone
Probably the most foolproof method of getting it to work is by getting yourself a copy of QuickTime Pro plus whichever codecs you need (the latter are often free). That'll allow you to just open up a movie file, hit the Export option, find a suitable preset and away you go.
I feel compelled to point out by the way that whilst, yes, the iPhone's codec support is a bit limited, the codecs it does support are good, and are much easier to work with than the codecs from which you'll be converting. (AVI, for example, is an utter nightmare as it's just a container that can contain one of a wide range of different actual video formats.) WMV, whilst simpler, also isn't exactly renowned for its amazing quality either. So getting everything converted in to something more usable isn't such a bad idea. Smiley
tommo
Re: WMV onto iPhone
I use an awesome program called Handbrake http://handbrake.fr/ for... well, just about everything!
It can easily convert anything into iPhone format (even has a preset), including DVDs. I manged to get WALL-E from DVD to iPhone in just a few steps. There's even a nice guide here: http://www.online-tech-tips.com/computer-tips/handbrake-convert-videos-into-iphone-format/
Good thing about Handbrake is it's open source so it's widely used and well supported.
Gets my two thumbs up.  Cool
Re: WMV onto iPhone
Handbrake seconded here. It can look intimidating at first but there's a lot of good guides online - afterdawn.com for example (that's how I learned to use handbrake). Having said that, there's a guide posted above too Smiley
Oh also handbrake is available for OSX too.
