W7 Arrived this morning
- Re: W7 Arrived this morning
- « Previous
- Next »
23-10-2009 9:09 AM
Click the highlighted area (see piccy) to get the browsing option. To remove password go to control panel, user accounts, select your account and select remove password.
23-10-2009 9:40 AM
Ah, thanks for the desktop answer, I'd missed that.
I don't want to remove the password (I think thats required to run scheduled tasks) I just want to bypass it at startup. But I'v now found what I was looking for, type in "control userpasswords2" in the run box and untick the box on the users panel - it's the same in Win 7 as XP.
Once you get past the 'pretty interface' its supprising how similar W7 is to XP, Microsoft don't seem to have put in much work under the bonnet, just a re-spray job - they won't like me for saying that
23-10-2009 10:08 AM
I did all that several times and it didn't work but then tried again and this time it worked - most odd
24-10-2009 11:50 AM
Quote from: paulgul can't get rid of those pesky shortcut arrows on the desktop icons (is there a win7 version of Tweak ui yet?).
If anyone else has an adversion for these shortcut arrows this program here work on Win 7
http://www.pcworld.com/downloads/file/fid,64901-order,1-page,1/description.html
Paul
24-10-2009 5:43 PM
and now it doesn't work again
Quote from: Oldjim I did all that several times and it didn't work but then tried again and this time it worked - most odd
So I gave up and just moved the folder into the default background folder location
- « Previous
- Next »
