Vista updates?
- Vista updates?
- « Previous
- 1
- 2
- Next »
Re: Vista updates?
16-10-2007 11:24 PM
James_H, Uhmm, I only realised the updates had eventually been successful by spotting the duplicate KB numbers in the list, the failed one's remain in the list. There doesn't seem to be anyway to remove them, I know that's being pedantic, but I'm tidy that way...perhaps they'll fall off the edge during further updates in the future.
Re: Vista updates?
16-10-2007 11:40 PM
I could well be wrong but I belive the failures stay there even after success, it is as it were a log rather than a summary.
Re: Vista updates?
17-10-2007 3:18 PM
Quote from: God Assuming your software is all legit go here: http://www.microsoft.com/genuine/ and allow the Active X control to install and then try updating again.
isn't number 11
"Thou must not use dodgy software" ?
"In Dalek Faye's voice"
"I Obey"!
- « Previous
- 1
- 2
- Next »
