VBA Macro Language
- Re: VBA Macro Language
VBA Macro Language
29-03-2011 4:08 PM
Recently when downloading documents from the internet and then copying and pasting to word 2007 those sections I want to print out the message "VBA Macro Language is required for this document do you want to install this now ?
I Have always selected no and then gone ahead and printed the downloaded sections without any trouble so it would seem I don't need it but any way I can get rid of this message (Other than reinstalling word)
We are born into history and history is born into us.
2 REPLIES 2
29-03-2011 5:47 PM
up to you mate
http://support.microsoft.com/kb/823227
29-03-2011 5:57 PM
I Have seen this article but it refers to word 2003 not 2007 !
To be honest it is more trouble reinstalling ( which I will have do do at some time in the future) than just clicking on no to the install request and then just continuing.
But thanks for checking it out anyway
