Using my Vodafone Nokia6300 as a modem
- Using my Vodafone Nokia6300 as a modem
19-08-2007 4:43 PM
I have been using my Orange Nokia6230 as a modem for my PDA for years, and have had no problems. However, I am now trying to use a Vodafone Nokia6300 with a laptop, and am unable to get a connection. The phone does connect to GPRS when I simply browse using only the phone.
I have been able to pair the two Bluetooth devices together, but the phone doesn't connect to GPRS when I try to view websites on the laptop. I assume that I need to enter some settings to the laptop to get it to tell the phone to connect to Vodafone GPRS, but I have no idea what to enter, or where. I'm a "PAYG" customer if that makes any difference, and using WinXPHome-SP2.
I'm sure the answer's obvious, but I can't figure it out!
If anybody can help, I'd appreciate it.
2 REPLIES 2
Re: Using my Vodafone Nokia6300 as a modem
19-08-2007 5:12 PM
I've solved it now. If anybody's interested, I'll post the solution later.
27-08-2007 12:40 AM
Quote from: PJ If you could post your solution I'm sure that it will be helpful to someone.
Glad you've managed to solve your problem.
When i usewas in india i linked my mobile via a USB connection / bluetooth / infrared installed it as a modem (drivers were required) and used a DUN connection...
