Using Hub 2 with TP-Link Deco X50 Wifi 6 PoE
roblongrigg
I've just started using Full Fibre with a Hub 2 at a new house. The house is long with some internal stone walls so I'm considering buying a mesh such as TP-LinkDeco X50 Wifi 6 PoE to enable wifi to reach the rest of the house
Does anyone have experience of using TP-LinkDeco X50 with Hub 2?
Do you have any recommendations about how best to configure Hub 2 to work with a mesh product like this?
Thanks for your help,
Rob
2 REPLIES 2
Re: Using Hub 2 with TP-Link Deco X50 Wifi 6 PoE
Hi @roblongrigg welcome to the forum
If you are going full fibre you put the Hub two in a draw for safe keeping
You connect the ONT to the Deco devices WAN port and configure it for a PPPoE, using your broadband username and password.
There is no requirement for a VLAN tag.
HTH
RealAleMadrid
Fixes: 68
edit: Deleted post. @Dan_the_Van was quicker than me.
