Router (with Guest network) and switch
khaled35
Hi, I currently use the Hub2 and a really old TP Link gigabit switch. I'm looking to upgrade to a router that allows guest access so I can connect stuff that I'd rather didn't have access to my network. Looking for something not too expensive and that just works. I'm happy with the Hub 2 but just need guest access.
2 REPLIES 2
Fixes: 1,495
Re: Router (with Guest network) and switch
Moderators Note
This topic has been moved from Full Fibre to Tech Help
Mustrum
Fixes: 81
@khaled35   it would help if you expanded your criteria. I was about to suggests a TP Link VR 600 DSL combined router/modem, but then noticed you are on full fibre so you don't need the modem bit.
No point going with a WiFi 4/5 router if you are on fibre speeds above 300Mbps.
So have a look, and do a bit more research on what you really want.
https://www.tp-link.com/uk/explore/wifi-router/
