Using DVD -RW for the first time....Help....
dgreen007
I'm trying to burn some files to a DVD-RW but an error messge has appeared saying
'Write error at 0(16) - Code 05 30 08 [illegal request, cannot write, application code mismatch]"
I've been using this particular software (which converts .avi files to .bup files etc and burns to DVD) for a couple of years with no real problems.
I was using DVD-R and decided I would like to use rewritable media (for obviousl reasons) so I bought Verbatim DVD-RW 4x which was recommended as a stable and reliable disc.
This is literally my first attempt with the DVD-RW and I am stumped.
Am I forgetting to do something really basic like formatting the DVD or is it simply the wrong DVD for my drive?
Or maybe something else.
Thanks.
13 REPLIES 13
Oldjim
Resting Legend
Fixes: 63
Re: Using DVD -RW for the first time....Help....
Is this with an Apple Mac
If it is a PC which burning software are you using and what is the DVD writer
dgreen007
Sorry for lack of info.
I'm using a PC running XP.
The DVD burner is SONY DVD RW DW-U14A
Oldjim
Resting Legend
Fixes: 63
A quick check threw up this spec link to Aria which states
Description:
      Mfr Part Number: DWU14A
      DVD-R Write Speed :
      1X, 2X, 4X max.
      DVD-RW Write Speed :
      1X, 2X max.
      DVD+R Write Speed :
      2.4X, 4X max.
      DVD+RW Write Speed :
      2.4X, 4X max.
You could try forcing a 2X write speed otherwise you will need some 2X disks - I know that 4X disks should work on a 2X burner but often they don't
To be honest I would buy a new DVD drive as they are dirt cheap now -
artificer
you need to format the dvd rw once, after which you erase when you rewrite.  then you can write in the usual way.
dgreen007
Thanks to both of you for your advice.
I will try to format them first and then perhaps consider a new drive if this does not work.
How do I format the disk - what software do i use.
Sorry for sounding naive but I have never had to do this before.
HPsauce
Windows XP does not include any "proper" DVD software, though it may recognise a blank DVD-RW and offer the option to format it.
Did your DVD drive come with a software disk, they normally do with at least some basic "burning" software?
dgreen007
Unfortunately my machine was bought from Mesh about 5 years ago and didn't come with any additional software.
I do however have Nero, would this have the facility to format the disc?
HPsauce
Nero has many versions. Mine (which came with DVD drive) includes an "Erase DVD" function - if yours has that it should do it.
Oldjim
Resting Legend
Fixes: 63
i haven't used RW for a long time - I just use R and junk it when it is full and start a new one.
That aside I believe that if you burn a DVD RW with Nero it asks if you want to format it if it isn't already
dgreen007
Thanks for all your advice.
I exchanged the DVD -RW for DVD +RW and they work perfectly.
Just one other quick question... Do I have to reformat the disc every time I want to use it again, ie to delete everything on it or is there a simpler way.
If I want to keep certain files on the DVD and delete only certain ones, can this be done?
Cheers
Oldjim
Resting Legend
Fixes: 63
Yes you can just delete the files you don't want and carry on.
A word of caution - never rely on a RW disk to store critical information. They can sometimes go wrong.
That is why I never use them as the cost of a decent DVD R disk is only about 20p and all I do is not finalise the disk until it is full. In this way I can keep adding files as necessary
dgreen007
Thanks Oldjim,
I was using the R discs to transfer stuff to be watched on my DVD player in the TV room and then I simply discard them so there was a lot of wastage.
I thought that by using RW discs I could save myself a few quid and help the environment to boot 🙂
So to simply delete the files I would use good old Windows explorer - would this be sufficient?
DG
cjags
Fixes: 4
To erase the DVD RW you could use a free utility like ImgBurn http://www.imgburn.com/
There is an erase option under tools > Drive > Erase Disc
