Usb hub issues
- Usb hub issues
- « Previous
- 1
- 2
- Next »
Re: Usb hub issues
26-12-2015 4:42 PM
Yes, well, hardware is buggy, especially cheap things like USB hubs. Even if things do basically work OK, like my hub I described, that doesn't mean it works 100% correctly according to how the USB standards say things are supposed to work. My hub is even supposed to be USB Hi-Speed certified, but then I suppose anyone could put that logo on the box.
I still think there's probably some clues as to why it doesn't work in the kernel log messages (readable with dmesg), or comparing the detailed output from lsusb -v might show something.
Re: Usb hub issues
31-12-2015 12:09 PM
OK plugged in to the pi-zero
unplugged
So not seen AT ALL. OK it is going through another hub but I need a hub connected to get wifi.
Got another hub today, and it works fine on the zero.
The usb flash drive was plugged in to the hub, plugged into the working hub.
Got a refund of the seller since the hub didn't work on the pi, so am happy with the new hub.
Quote pi@raspberrypi:~ $ lsusb
Bus 001 Device 004: ID 0bda:0179 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
unplugged
Bus 001 Device 010: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive
Bus 001 Device 009: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4 USB 2.0 Hub
- « Previous
- 1
- 2
- Next »
