Toshiba SMART tvs no radio streaming
RAFsteve
Greetings! I have recently bought Toshiba 24WL3A63DB (2019) SMART tv just because I have no aerial available in the room its intended for.
All the TV app channels work fine but none of the pre-installed radio apps connect, at least no sound.
I thought it may be a fault with the tv so they sent me a replacement tv with exactly the same result. In another room I have a Roku Express that plays any internet radio without problem. I also have a Google nest Mini which works perfectly.
I use the supplied Plusnet Hub One WiFi router and also have tried ethernet cable to tv.
Any experience or ideas please?
11 REPLIES 11
markuswelby
Re: Toshiba SMART tvs no radio streaming
Might be worth checking for system updates or app updates.
After that my next step would be, set my 4G smartphone as a wifi hot spot, log the TV in to the wifi on the phone and see if the radio app/s work then over 4G or even 3G on a good phone.
Ubuntu-MATE 18.04.3 LTS (Bionic Beaver) 64-bit
RAFsteve
Good call, Toshiba say they will send me firmware to do a re-build. I'll try the hotspot. seems a sensible idea.
markuswelby
You're welcome. All the best!
RAFsteve
I got it connected to my phone hotspot okay and could stream iPlayer etc but still the installed radio apps not functioning. I'll await Toshiba's firmware update.
Cheers.
Mustrum
Fixes: 81
Does it work in a room with an Ariel connected?
RAFsteve
Yes but thats only using Digital Terrestial TV (Freeview) through the roof aerial. It still wont run radio apps over WiFi as a SMART TV (not so smart really).
No aerial socket available in this room unfortunately which was the reason for buying a SMART TV.
RAFsteve
I just feel its unlikely to be the tv at fault as Ive tried two brand new ones. Must be an issue with the Plusnet connection
Mustrum
Fixes: 81
How must it be the router if it also does not work from your phone hotspot?
Are you sure these apps should work the way you think?
RAFsteve
Because I shut down the router and used data on my mobile.
RAFsteve
Oh, I see your point.
RAFsteve
...just now received new Toshiba software update, installed and was greeted with a new Secure Smart TV ToU which I've never seen before even on the original 1st intallation proc.
Guess what? All radio apps now function correctly..🤔
Installed on both sets, both now properly functioning.
Obviously not the router, Toshiba released a non-working system.
