Tomorrow is Firefox 3 day
- Re: Tomorrow is Firefox 3 day
17-06-2008 12:04 PM
Hasn't anyone ever heard of UTC?
17-06-2008 12:59 PM
Meanwhile, have had a root round and found that it can be set not to accept block third party cookies so am pleased about that.
Bookmarks are slightly differently organised but no problem really.
17-06-2008 1:05 PM
The final version won't be released for at least a few hours (you need to be on California, USA time for some reason).
17-06-2008 1:10 PM
17-06-2008 5:26 PM
17-06-2008 5:43 PM
If so you can (and should) elect to have it downloaded and installed.
Don't try to download it from the website - let your Linux package manager handle it for you.
All updates will then come from authenticated sources - and include any dependent packages that may be required.
17-06-2008 5:59 PM
17-06-2008 6:08 PM
17-06-2008 6:20 PM
Quote from: pierre_pierre I am using an Eeepc 4g with linux and Firefox pre installed, do you know if Firefox 3 would self install on that? - only had the machine a couple of days and away from base happily using the Pubs WiFi, plus thunderbird Imap, gorgeous
Personally I will be sticking with FF2 on my eee, Asus may add it to their updates, but would not hold your breath. Plus because of the way the file system works on the eee, if you upgrade, you will not recover the space used by FF2. And with only 4G to play with, that is space I will keep for other things.
Chilly
17-06-2008 6:39 PM
17-06-2008 6:43 PM
Quote from: jelv Well there's a surprise - no response from http://www.spreadfirefox.com/ - looks like it's overloaded!
What is not a surprise, of course, is how well the viral marketing is working. Nice one Mozilla
17-06-2008 6:44 PM
17-06-2008 6:47 PM
I'm not sure if this link is for the official record setting, but: http://download.mozilla.org/?product=firefox-3.0&os=win&lang=en-GB
Downloads from Mozilla servers, and it's pretty quick too (I just took the 2.0.0.14 download link and changed it to suit). I can't remember looking at the RCs about screens - did they have RC tags or just simply "version 3.0"?
17-06-2008 6:50 PM
Quote from: Oldjim I am not touching it until I see the reports from the brave guinea pigs
I am with you Oldjim.
17-06-2008 7:01 PM
cp:quote
