Thunderbird update fail
shutter
Fixes: 67
Running Windows 7 Professional, NEW INSTALL last weekend... running Thunderbird,...( same thing ... new install last weekend )... for the past 4 days, I have been getting a message across the screen, that the latest "update" for Thunderbird has failed.... and I should restart Thunderbird to try again.
I have Thunderbird running all day long... so I close it down at night, and then restart it in the morning..
The failure message only appears late in the evening.. ( near to 11 pm ).
If I downloaded a new copy of Thunderbird, will trying to install it, cover the update?   Will it destroy the current emails on the hard drive... and will it destroy the address book, by trying to install a new copy over the old one....?
7 REPLIES 7
TheRoadCrew
Fixes: 13
Re: Thunderbird update fail
Have you tried this?
Might be a good to backup your user profile first.
shutter
Fixes: 67
@TheRoadCrew  Thanks for the linky....    Have tried the "run as administrator" suggestion from the start menu... will leave it running today and see if that fixes it.  then go from there.
cheers
Wink
ReedRichards
Seasoned Pro
Fixes: 25
Many email programs can be uninstalled and re-installed leaving the existing messages and address book intact.  Even the email account details may remain, typically minus the password which needs to be re-entered.  I don't think I have ever tried this with Thunderbird but it would be a let-down if it was not capable of doing the same.
shutter
Fixes: 67
Update.....
Have not seen any more messages about update ( failure )... or otherwise.... so am assuming that the "run as aministrator"  has done the job..
Thanks guys.
Wink
Luzern
Fixes: 9
@shutter Is the TB properties showing file version 52.8.0.6710 now? That's mine modified 23/5.
shutter
Fixes: 67
Hmm... my "About Mozilla Thunderbird" window is showing 38.5.0    (JUST OPENED AND "LOGGED IN" )
Update failed....  Download the latest version
You are currently on the release update channel
So I clicked on the "download"  and it shows as version 52.8.0    so not sure where I got the 38.5.0 version from ! ! ! ... no wonder the update failed ! ! !>..
will see what happens with the new download./install ...............>
OK..... done the install, and,....... All my address book, and all my previous emails, have been saved and installed into the updated version.... now showing version 52.8.0
(no need to save the "profiles" folder...  {but I did,.... just in case ! ! ! }  )
Thanks for the "heads up" on the version number.....   Appreciated. Wink
Luzern
Fixes: 9
 BTW For profiles Mozbackup is still useful for Firefox Thu'bird, and I think their offshoots.
