The practicalities of moving your email (NOT Greenby...)
paul_blitz
Fixes: 4
So, as I posted elsewhere, I just moved my email accounts from Plusnet to Mythic Beasts. My email uses my own personal domain names, and used to be forwarded to my "user@xxxx.plus.com" account. I needed to make my email instead get forwarded to Mythic beasts
One of the issues is "what happens to my old email?". Here's a few not that might give you some help. I'm going to assume that you are using some sort of mail client on a PC, so maybe Outlook or Thunderbird
1) POP3
This is easy: create a NEW email config for your new email service. All your old mail will stay (locally on your PC) in the folder structure for the old email: when you are happy that the email HAS moved over, and thus there's nothing left to collect at your old email service, you can simply copy or move the email or the folders from the old email setup to the new email setup.. Once you've done that, then you can simply delete the old email setup.
2) IMAP
The big problem here is "what about my old email, it's all on my old server?". My wife uses IMAP on her tablet for her emails. I was using Outlook on my PC to "monitor" my wife's email, using IMAP. So, I copied all of her historical emails from the IMAP account folders into a local folder on my PC. Then I set up the new IMAP account for M-B, and checked it was working, then I just dragged that local email into the new account's IMAP folders. Outlook will then upload all those emails to the IMAP server. Then, on her tablet, I just edited her email config: it lost all the old IMAP emails, but reloaded them all (might take a while) from the M-B server.
(If you are feeling lucky, you could just copy from the old IMAP folders to the New IMAP folders: I wasn't THAT brave!!)
3) More advanced stuff.
Had I simply switched the forwarding, the switch would have been instant: My email goes into Namesco, then it would be forwarded to M-B instead of Plusnet. However, I also decided to take the bold step of moving the DNS for my personal Domain Names over to M-B: their DNS is actually pretty good, flexible, and easy to configure. The problem is that it can take up to 24 hours for the world to realise there has been a change, so email could go EITHER to Plusnet OR to M-B in that period.... Ooops!
So, I got clever: when I set up my new email accounts at Mythic Beasts, as well as getting it to put the emails into an M-B email mailbox (which is where my email client would collect them from), I *also* told it to forward a copy on to my plusnet email...
So, originally, the email flow was email -->Namesco --> Plusnet, now it's email --> M-B --> copy sent to Plusnet. This means that, until I changed my email client setup, I would STILL get my email sent to Plusnet! Sweet!
Once I was happy my emails were 100% flowing via M-B (I used the M-B webmail - which actually WORKS!!! - to see when mail came into my new M-B), I could - almost at my leisure - move my email account over to use MB. Rather than setting up a new email config on my Outlook, I just repointed the existing one to the new M-B server. Ok, so I got a day's worth of duplicate email - big deal!
4) What about my Phone / Tablet?
With MY account (POP 3 to my PC), I have it set to leave 20 days of  email on the server (with POP3,everything gets downloaded to my own PC). My phone / tablet then connects to the email server using IMAP, which means I don't have to ever to any email pruning: it automatically gets deleted when my POP3 email setup deletes it on the server after 20 days. The only (non-)issue was that, when I moved over, there was no email history: whilst I COULD have set up a temporary IMAP account on my Outlook, to copy some emails over (see (2) above), I just left it: my phone is mainly used to see new emails as they arrive, it's not THAT often I need to refer back.
For my wife's account (which is 100% IMAP): I did step 2 above, using my Outlook to populate the new email account at M-B with her historical emails. On her tablet, I deleted her old IMAP account, and set up her new one: the IMAP on her tablet immediately started to 'collect' all her historical email.
In both cases, no email was lost.
5) And my Laptop?
So, I have a laptop, and historically, I used it weekdays. I historically set it up to use POP3: no problem, with 20 days email on the server, after the weekend, it would just catch up... but it meant I had access to my email offline.
I'm now retired, so it just tends to get used when I go on holiday / visiting family. It's still using POP3, but there will be gaps of emails missing: not an issue, my email is all on my main PC. So I just synced up the email from Plusnet, then changed the account to point instead to M-B instead: works fine.
Whilst I used Outlook to do this, it should be 100% possible to do this with Thunderbird. Whilst you COULD possibly do it all using a tablet of a phone, it's likely to be a lot more fiddly!
6) How does this compare to the current Plusnet email migration?
Many of you will be using your "user@xxxx.plus.com" as your email address. The problem with that is that if either (a) you move your broadband (and thus your email); or (b) plusnet decides to move your mail, then you may be a little uncertain about how secure your historical email is, and that you might lose some. It is EXACLY for that reason that, many years ago, I got my own domain name, so that my email address belongs to ME. I control it, I can forward it to wherever I like. If I make a change, it's 100% under MY control. I would strongly suggest that you might look at doing the same.
In the meantime, if you use Thunderbird or Outlook on a PC, and you use IMAP for your mail, then you can do the same as in step 2 above: take a copy of your email into a local folder. If the Plusnet to Greenby migration works, then no problem: you just point your email account over to Greenby (instead of plusnet): your existing emails will apparently be deleted, then all retrieved again from your new Greenby account. If you have any issues, then you still have that backup in that local folder.
7) Tidying up the old stuff?
THEORETICALLY, I could have use the Plusnet Webmail client to go and tidy up the old email, but if I'm honest, I'd rather just watch paint drying peeling peeling, it would be 100 times quicker and more reliable / satisfying! I'll just let Plusnet do their thing, migrate it over to Greenby, then, if I feel so inclined, I'll go there and clean it up.
Its not really a problem: last time I looked, I had about 400 emails (mostly spam!) over the last 20 days, my wife probably had under 1000 in her IMAP account.
I hope this gives you a few ideas about how to move email accounts. Happy to try and answer any questions.
21 REPLIES 21
Fixes: 558
Re: The practicalities of moving your email (NOT Greenby...)
@paul_blitz
Did you look at Imapsync https://imapsync.lamiral.info/
There's an online tool which will allow up to 3Gb mail storage to be transferred. A installed the offline tool it in a Linux VM and have used that to successfully transfer two email domains. Theres a really useful link here https://imapsync.lamiral.info/FAQ.d/FAQ.Migration_Plan.txt which explains how to handle the situation of mail going to either old or new server during the migration period.
Fixes: 466
Moderator's note:
Thread moved from Email to Tech Help
paul_blitz
Fixes: 4
An interesting idea, but it's a command line thing, and for most people, that's just not gonna help, which is a shame!
The problem with any one-off migration tool is just that: it's a one-off, so not exactly a large audience. So unlikely to get a really simple GUI etc etc...
But useful to know there IS a tool.
Fixes: 240
The web page tool is a simple enough GUI - put the credentials for source and destination mailbox into the webpage click the go button and the job runs.  What more do you really need?
You can leave the browser page open and click the run button as often as you need during the 48 hours (max) during the migration window.  You can set up multiple tabs - one for each mailbox - and just leave them there.
This is not something you need day in day out - it’s a short window one off job.  The free tool is more than adequate for Plusnet users given it’s impossible to have a mailbox as big as 3GB.
paul_blitz
Fixes: 4
Ah, sorry, I was scanning down, and started seeing all the CLI stuff, but now I look again, yes, I see the web page link, and yes, it DOES look pretty straight-forward!
JBryan
Thanks very much for the useful info here. You are describing just what I want to do, which is use my own domain name (currently with Gandi) but move away from forwarding to having email with Mythic Beasts. Can you just clarify, I'm not sure what you mean when you say you got a copy email sent to Plusnet during the changeover period. Which provider is sending the copy? Also, was it complicated to change the MX records on your domain when you set up your new email account with Mythic Beasts, or did MB guide you through the process? Many thanks
paul_blitz
Fixes: 4
Ok, great questions:
1) forwarding email. So, you start your MB email setup by creating "Mailboxes": these are where you can send mail to, and where you can use POP3 / IMAP to collect the mail from. There's one for me, one for my wife etc. If you have multiple domain names, then it's your choice: does your email from all those domains go to a single mailbox, or to different ones?
Next, in the "email" section for my domain, I can add email addresses, so "paul@domain" etc. there's also the "default. These are what inspect the incoming mail. Each of those needs to have "actions" attached. The most obvious is "save it in Paul's mailbox" (set up above!), but you can do MULTIPLE things: "send an auto-response", "discard spam", and "forward to another address": All I had to do was to use that to save it in the local mailbox as well as forward a copy to my plusnet email (so using your "native" plusnet email address)
2) MX records (and other important records too!): MB has a very helpful "email checklist" that will let you set everything up:
Follow the checklist below to associate xxxx.me.uk with a Mythic Beasts hosting account:
Configure hosting account
The following hosting is configured on account bfemail on host pallas:
Configure DNS records
DNS is configured correctly.
Set nameservers for domain
xxxx.me.uk is configured to use Mythic Beasts' nameservers.
Configure Sender Policy Framework (SPF) record
xxxx.me.uk is using the standard Mythic Beasts SPF record. If you wish to configure a custom SPF record, please use the DNS management page.
Enable DomainKeys Identified Mail (DKIM)
DKIM is enabled for your domain.
MB's DNS has a "Full View" where you get to see everything, as well as a "simplified view" that's... well, simpler! I can't instantly find where they tell you their MX details, but here's a copy for you:
300
MX
10
mx1.mythic-beasts.com.
300
MX
10
mx2.mythic-beasts.com.
So, wherever your DNS is actually hosted, that's what you need. Whilst my DNS is still "managed" by Namesco, I updated my NameServer records to point over to Mythic Beasts, so that's where all my DNS is now set up.
The issue is that many DNS providers out there set the default TTL (time to live) to be 24 hours, which means that it can take up to 24 hours for the change to kick in, and that "up to 24 hours" will vary depending on the site. (you can set the TTL per record in the MB's DNS setup, it's 300 secs above)) That's why I got it to also forward emails to my plusnet account, so I didn't lose anything.
I actually had a "spare" domain name, so I used that to try things out.
Hopefully that extra information helped, feel free to DM if you need more help.
JBryan
Thanks very much for this. Now I just need to have the courage to make the break and move on!
paul_blitz
Fixes: 4
Yes, I know that feeling.... the feeling of "I hope I don't screw this all up, and lose lots of emails"!! That's why I used a 'spare domain' to check things out first! But I now feel very comfortable with Mythic Beasts.
BTW, you might need to play a bit with the spam setting: it will add a header to any emails that show the spam score (some clear spams were getting surprisingly low scores): you can set a threshold at which it will delete them.
So, take a deep breath: your new year resolution is to (a) move that email; (b) go and delete all the mailboxes on your PlusNet account.
(I think that last step is even more scary!!)
Getting DKIM functioning on MB's implementation of subdomains is something that is currently eluding me.
Not a show-stopper. I may get there.
paul_blitz
Fixes: 4
I didn't do any sub-domain stuff, but the DKIM for the main domains were pretty much "tick the box and MB does it for you" from what I remember. All I know is that I now have the set of DKIM records needed in the DNS for each of my domain names!
Fixes: 558
@Anonymous
Do you actually need to do anything ? DKIM for the main domain signs in 'relaxed' mode so will automatically cover subdomains
Charleso
I'm in the process of moving email to Mythic Beasts as well, which likewise I have trialled with an additional domain.
Currently PlusNet host my domain, DNS, email and web(unused) as grandfathered capabilities.
I had hoped to initially just update the email hosting by configuring my own MX records in the PlusNet portal. The problem is having done that this morning, and an nslookup suggesting the PlusNet publish MX records with a 5m TTL, nothing seems to have changed.
My current settings look like this:
I had tried to use @ as the left field as most examples do but this is not allowed in the PlusNet portal so I tried blank.
Another thread on this forum advised they had got it working by specifying the full domain with a trailing . in the left hand field so this is what I have currently.
For additional clarity here are the full fields showing both left and right addresses having trailing . characters.
I'm aware that usually I would not put in a low priority record for `mx.core.plus.net.` but I wanted some fail over for now and I have tried it with and without this record.
What am I doing wrong here?
Is this area of the portal now effectively defunct so the changes will never take effect?
Or are the changes made here updated at a much slower rate than the 5 minute TTL seems to suggest or the usual 30 minutes quoted for mailbox changes? These settings have been updated for about 3 hours now with no external changes:
Fixes: 240
I do not think you need to put anything into the left field.  In context you are configuring for yourdomain.co.uk so the left field does not need any qualifier.
However in passing, you are going to encounter issues if you attempt to send email via Mythic Beasts, as the MB SMTP server is not going to be in the SPF configuration.
What are you seeking to do here?  Frankly, life might be far simpler to...
  1. Set up the MB service / build the mailboxes
  2. Use IMAPSYNC to copy the Plusnet hosted mailbox content to MB
  3. Move the domain registration to MB
  4. Configure the MB DNS
  5. Change name servers to MB
  6. Keep the IMAPSYNC running until there are no more new emails arriving at Plusnet
