Task Bar
psk10
Task Bar
Has anyone noticed that since SP3 has downloaded when right clicking on the task bar the and then on toolbar the address bar is not there any more. M/S said they were forced to remove it for legal reasons .
2 REPLIES 2
bobpullen
Fixes: 316
Re: Task Bar
I wasn't aware of this. A quick Google search suggests that there's a few solutions out there. Take a look a Niver's post here. Alternatively there's a freeware app available for download here.
psk10
Re: Task Bar
Thanks for for the advice Bob , i did a little checking to on google to , at 1st i could not understand where it had gone , but i also have a Pc on Vista which has the box at the bottom so it,s not a problem , i just thought that other people would also wonder where it had gone and spent a bit of time trying to find out why it had gone from the toolbar  .
